- While the "5 Easy Steps" 1 year 4 hours ago
Hi stevepier,
Does the logon box popup? Can you access:
http://192.168.1.1/Upgrade.asp
by entering username root and password admin?
Hi kong thanks,
i've changed password via telnet
i changed password using this guide:
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=545674
telnet 192.168.1.1 - telnet user root and password admin
nvram set http_passwd = "admin"
nvram commit
then i was able to enter through web interface
using login admin/admin
Thanks anyway!
Regards!
Steve
Can you get me the output of these commands:
ls -la /dev/scsi/*
ls -la /dev/scsi/*/*
ls -la /dev/scsi/*/*/*
dmesg
Ok.
http://pastie.org/2602343
a second pastie after a reboot : http://pastie.org/2602685
Hi val532,
what hdd case is this? Anyways, as you can see from the dmesg output:
scsi 0:0:0:0: Direct-Access SAMSUNG S2HZA08964 PQ: 0 ANSI: 2
sd 0:0:0:0: [sda] 3907029168 512-byte hardware sectors (2000399 MB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Mode Sense: 1a 0c 00 00
/dev/scsi/host0/bus0/target0/lun0: p1
The kernel does not recognize 2 seperate drives here. There are two possibilities why it fails.
a) you changed the raid mode and did not reset the controller. when changing raid modes of such raid controllers you must press the reset button.
b) the current kernel used in this firmware does not support this specific hardware, this is rather unlikely
To me it looks like the mode of this hdd case is set to JBOD.
Hi yes my case is in JBOD, on windows i see the two HDD separately. And y have an USB case for HDD with an 1tB in and a seconde USB drive conected on the 1tB, and DD WRT see the two USB HDD correctly.
I have no idea of what i can do for my two HDD (in my case with SIL5744) can view by DD WRT.
Multiple device support with JBOD over USB needs a kernel >=2.6.31. Since broadcom drivers currently only support kernel 2.6.24 you are out of luck here.
I don't think we will see a new kernel soon on the broadcom units.
Ah ok :(
What does syslog want to say ? Not even google knows about it.. ;-)
What could this spamming wlc_send_bar be?
Oct 1 10:04:57 dd-wrt kernel: wl0: wlc_send_bar: seq 0xfd9 tid 0
Oct 1 10:04:57 dd-wrt kernel: wl0: wlc_send_bar: seq 0xfdd tid 0
Oct 1 10:05:12 dd-wrt kernel: wl0: wlc_send_bar: seq 0x415 tid 0
Oct 1 10:05:36 dd-wrt kernel: wl0: wlc_send_bar: seq 0x973 tid 0
Oct 1 10:05:57 dd-wrt kernel: wl0: wlc_send_bar: seq 0x611 tid 0
Oct 1 10:07:16 dd-wrt kernel: wl0: wlc_send_bar: seq 0x182 tid 0
Oct 1 10:07:16 dd-wrt kernel: wl0: wlc_send_bar: seq 0x183 tid 0
Oct 1 10:07:16 dd-wrt kernel: wl0: wlc_send_bar: seq 0x184 tid 0
Oct 1 10:08:36 dd-wrt kernel: wl0: wlc_send_bar: seq 0x33f tid 0
Oct 1 10:08:36 dd-wrt kernel: wl0: wlc_send_bar: seq 0x340 tid 0
Oct 1 10:09:13 dd-wrt kernel: wl0: wlc_send_bar: seq 0x3dd tid 0
Oct 1 10:10:55 dd-wrt kernel: wl0: wlc_send_bar: seq 0x683 tid 0
Oct 1 10:10:55 dd-wrt kernel: wl0: wlc_send_bar: seq 0x686 tid 0
Oct 1 10:12:12 dd-wrt kernel: wl0: wlc_send_bar: seq 0x82b tid 0
Oct 1 10:12:14 dd-wrt kernel: wl0: wlc_send_bar: seq 0x82d tid 0
Oct 1 10:12:15 dd-wrt kernel: wl0: wlc_send_bar: seq 0x82e tid 0
Oct 1 10:13:57 dd-wrt kernel: wl0: wlc_send_bar: seq 0xc97 tid 0
Oct 1 10:17:27 dd-wrt kernel: wl0: wlc_send_bar: seq 0x6e8 tid 0
Kong,
Nice job on the firmware. Like the latest version, however, 3 issues came up:
1. SNAT only allows traffic from the router subnet (i.e. 192.168.1.0/24) This is causing an issue on my network that has another router behind the firewall that DD-WRT router traffic to through static routing table (i.e network 192.168.2.0/255.255.255.0 is routed through 192.168.1.3). Don't ask, but I am using a server to route VPN traffic through.
2. Access Restrictions still does not appear to manage the iptables firewall rules very well. I have entries stacking up in the lan2wan chain.
3. iptables-save symbolic link does not work anymore
Let me know if you need more info,
Allen
Kong... great firmware. Running it on Belkin F7D4301 with Transmission and NZBGet and an HP Photosmart Printer.
I have a 2TB WD drive mounting at /opt, /jffs, /swap and /mnt.
I have another 2TB WD formatted ext3 that I'd like to put into a hub off the router. When I try it works, except I'm getting nothing under /opt. I figure it's being mounted twice, from what I've read.
Is there a tutorial on how to get multiple drives going?
Kong, et. al.,
I've read some other threads on this and can't get it to work:
1st USB 2TB drive with /opt, /swap, /jffs and /mnt mounts no problem
2nd USB 2TB drive, no label, mounted and accessible
I noticed /opt was empty. Is there an easy way to fix this?
I'm on the 10/26/11 v24-sp2 build.
Tried something different. Still with automount enabled I used UUID to mount the base file systems and they worked. However, the second drive also got mounted to /jffs?!?!
I'm going to try putting a label on the second drive's partition and see if that does anything.
Ok, it works... first drive mounts properly, second mounts under /tmp/mnt/disc1-part1!
Going to try pressing my luck. I have a third 2TB drive I'm going to format Ext3 and see if I can get it going too. If it works. I'll have 6TB hanging off the router and a printer!
I'll report back.
Whoo hoo!
Ok, final config is this:
Belkin F7D4301 w/ two USB ports
DD-WRT v24-sp2 10/26/11 stdkong
Transmission - Torrent downloads
NZBGet - Newsreader
1 USB Hub (unpowered as all devices have their own p/s)
3 Western Digital 2TB USB drives
HP Photosmart 7960 shared (tested and works)
All working well. Great job Kong!
Where can I find this firmware? All links in the article are 404.
Please, reload firmware for Belkin F7D4302
This link http://www.desipro.de/ddwrt/dd-wrt-usb-ftp-samba3-vpn-O2-newd-broadcom.bin is not working.
I need firmware for Belkin F7D4302
Latest available build are there: http://www.desipro.de/ddwrt/K26/r17865/
