- R8000P would be grate to see. 2 years 1 month ago
- Have a R8000 but ordered a 2 years 1 month ago
Kong,
@Kong:
Link speed stays at 144Mbps;
@Iqbal,
latest stable minidlna 1.0.22
@ReDaLeRt,
@Kong
Kind regards,
@kong:
Weird?
Thank you in advance.
@ Dark_Shadow
@Kong:
Link speed drop AGAIN:
Hello King Kong,
Here are my results.
3) This is for other users.
@Kong:
@Kong:
TCP window size: 5.00 MByte
TX errors;
Jumpy wifi signal;
Low throughput on wifi;
Low link speed sync.
Setup:
Client 2: Realtek Gigabit LAN
Results:
It gets curious:
@MadRocker:
Best regards,
Best regards,
Hi everyone,
Petty question here,
Thanks @kt_haddock,
