https://apps.fcc.gov/eas/GetApplication … id=1497548
here is a link with the internal pics of the wndr3700v3 from Netgear so hopefully someone can help develope an openwrt or dd-wrt or tomato version firmware for this router if neede hope this helps
https://apps.fcc.gov/oetcf/eas/reports/ … 1200166%27
this is a link to all information about the wndr3700v3 if needed to this is for a netgear router it's based on the broadcom 4718A1KFBG chip set
and the other chipset or processor not for sure is a broadcom BCM4331KMLG
Hope this helps out any developers for this firmware
I don't know about the hardware of the WNDR3800 but will check it out http://wikidevi.com/wiki/Netgear_WNDR3800 this link may help out some the WNDR3800 is based on atheros hardware configuration
The WNDR3700v3 is based on broadcom hardware chipset if this helps
Ok good luck with development I have no Idea how to develope or make firmware for wireless routers all i know how to do is update there firmware i will leave the development to the the developers as im not good with firmware
