Please help using USB drive
9 posts / 0 new
Blowfish64
Blowfish64's picture
I can't find any tutorial on how to get a USB drive working with the Kong DD-WRT firmware.  I have the drive auto-mounted as follows:
Disk 0:
Block device, size 746.5 GiB (801569726464 bytes)
DOS/MBR partition map
Partition 1: 2.000 TiB (2199023255040 bytes, 4294967295 sectors from 1)
Type 0xEE (EFI GPT protective)
GPT partition map, 128 entries
Disk size 746.5 GiB (801569726464 bytes, 1565565872 sectors)
Disk GUID 4F24B4A6-E6BE-DA48-B27E-DD29375C832F
Partition 1: 128 MiB (134217728 bytes, 262144 sectors from 34)
Type MS Reserved (GUID 16E3C9E3-5C0B-B84D-817D-F92DF00215AE)
Partition Name "Microsoft reserved partition"
Partition GUID E59C8428-215F-254B-BC52-23171DDBF744
Blank disk/medium
Partition 2: 2.729 TiB (3000455135232 bytes, 5860263936 sectors from 264192)
Type Basic Data (GUID A2A0D0EB-E5B9-3344-87C0-68B6B72699C7)
Partition Name "Basic data partition"
Partition GUID 0B768B5A-51E5-3140-A13F-8114DE15346E
NTFS file system
Volume size 2.729 TiB (3000455134720 bytes, 5860263935 sectors)
Partition 3: unused
Mountpoints:
/dev/scsi/host0/bus0/target0/lun0/part1 mounted to /tmp/mnt/disc0-part1
That's wonderful.  NOW WHAT?  HOW THE F@CK DO I ACCESS IT?
Subhra
Subhra's picture
There are so many ways of
There are so many ways of accessing your usb drive, e.g. using ssh/WinSCP, FTP, Samba and Windows Network Neighbourhood etc.
you can find the thorough guideline of using those in the following link ...
http://www.dd-wrt.com/wiki/index.php/USB_storage#Step_4_-_Enable_Network...
Blowfish64
Can't I just get it to show
Can't I just get it to show up on my Windows Network?
Subhra
Subhra's picture
You should find your USB
You should find your USB drive containt in "My Network Places" for Windows Operating System.
Subhra
Subhra's picture
Following is a link of
Following is a link of similar discussion ...
http://www.myopenrouter.com/forum/thread/32227/USB-How-to-get-it-working...
Hope it will help you.
Let us know about the result.
Blowfish64
Subhra said: Following is a
Subhra said: Following is a link of similar discussion ... http://www.myopenrouter.com/forum/thread/32227/USB-How-to-get-it-working/#11165 Hope it will help you. Let us know about the result.
The problem is there is no path that I can select.  When I click on the dropdown the only option is "--". Meanwhile under USB it still says my drive is mounted to
Mountpoints:
It's very frustrating.
Blowfish64
Anyone?
Anyone?
Blowfish64
So no one has an answer to
So no one has an answer to this simple question?
Subhra
Subhra's picture
Can you please give me the
Can you please give me the link to download the firmware you are using ??
