i installed shibby's tomato firmware and all was fine. I have read that i had to reset nvram so i did it.
Now the password has changed (i never changed it since i have the router, so i should be admin:password)
how can i manage to connect to the router and change this password or revert back to the initial firmware ?
Thank you all
admin:admin is the answer.
Thank you
