Till now I know only one one method to debrick WNDR3800, and it is using serial console. If you have the one, I can provide you the detailed procedure.
Subhra said: Till now I know only one one method to debrick WNDR3800, and it is using serial console. If you have the one, I can provide you the detailed procedure.
Do you have some pics of the connectors with details of each? I will be getting one next week and setting up a serial cable for it.
Till now I know only the serial console method to debrick WNDR3800. I want to have the knowledge how did you bricked it with OpenWRT ?? What is the current status of your router ???
What is the method to debrick the WNDR3800? Where can i find it?
I already have a USB-TTL Cable.
Please help.
The following pictures explain the pin connetions. You can use the same serial cable as that of the WNR3500L.
It is just for remainder that whenever you break the seal, the warranty will not be valid anymore, so be sure before breaking the seal.
Perfect thanks. I will post some articles on it once I have had a chance to mess with it.
Great post and highly informative too.
[url=http://www.sevenlocksandkeys.com/]Lexington Locksmith[/url]
[url=http://www.24by7locksolutions.com/]Locksmith Medford MA[/url]
[url=http://www.1a1lockout.com/]Locksmith Franklin MA[/url]
[url=http://www.sharpinma.com/]Watertown Locksmith[/url]
Nice post.Thanks for sharing.
<a href="http://www.sevenlocksandkeys.com/">Lexington Locksmith</a><br />
<a href="http://www.24by7locksolutions.com/">Locksmith Medford MA</a><br />
<a href="http://www.1a1lockout.com/">Locksmith Franklin MA</a><br />
<a href="http://www.sharpinma.com/">Watertown Locksmith</a>
DId anybody found it easy way to debricking WNDR3800 without serial cable, after using Openwrt?
I realy need it.
Sorry for my English.
Please help.
