Hi everyone!
This is my first post in the forum.
My name is Ben and I'm from Quebec City, Canada!
I just grabbed a Netgear WNR3500Lv2 yesterday and I flashed it with Tomato.
So far so good, I pretty happy with it but I just realise that I can only create VPN Server with OpenVPN.
Since I need VPN for my iOS devices when I'm on the go, I trying to find a way to use PPTP server.
If I reflashed my routeur with DD-WRT, will I be able to create a VPN server with this protocol?
I used DD-WRT with other routers in the past but I just want to be sure that this fonction is possible with the netgear ;)
Thanks a lot for your help,
Ben
I just flashed my router with dd-wrt.
I can enable the PPTP server but I can't get it to work :(
Any special settings?
Ben
Can you please share how did you enabled PPTP server in ddwrt for WNR3500Lv2 ???
Thanks for the link .
Just FYI, we just added PPTPD server to Teaman and Toastman builds of Tomato.
The new toastman build is the way to go. It is pretty simple to setup pptp and openvpn servers. I love this new build cause it works for my wife's Ipad.
Have you implemented that successfully on a 3500Lv2 router ?
Which firmware did you run ?
I have been trying http://www.myopenrouter.com/download/34850/DD-WRT-for-WNR3500Lv2-Initial-Release/ but no luck and I can't see/find anyone else implementing it successfully either unfortunately.
That's the whole reason for me buying this router and it's a no go as of now =(
Wasted money
As per my knowledge, PPTP server is not implemented in this DDWRT build.
