MyOpenRouter.com is not affiliated with NETGEAR®. NETGEAR is a registered trademark of NETGEAR, Inc. in the United States and/or other countries. Other brand names mentioned herein are for identification purposes only and may be trademarks of their respective holder(s). © 2020 All rights reserved.
i have 802.11g wireless adapter in my laptop. would i benefit from an N router. if not can I. what should i do?
I have a question for you all..My built in wireless just went on my toshiba laptop so i had a netgear wireless usb 54g laying around and it runs good..I just received a new mini realtek wireless (N) usb and the speed just dropped in half..
I am running a netgear wireless (g) router..Do I need a wireless (N) router???
Dave Chud, yes, you will need an N router in order to get N speeds with your N wireless USB adapter. Some of those mini USB adapters don't get a very good signal, in my experience. But back to your question, if you don't have a need for faster network performance (like streaming movies), then you're probably fine just to stay at G speeds and use the G USB adapter.
Where we live internet is provided to us by the owner of the apartments, I've always assumed that he was using a "g" router. If I were to purchase a wireless N adapter for my laptop would it improve the performance of the internet at all or would I not get any benefit from it?
I would like to buy and install a new wireless router.
I have to connect the router to 2 devices
1. HP Premium Series HDX18 Laptop
2. Desktop installed with Belkin wireless G Desktop Card 802.11g
which one i should buy?
Wireless G / Wireless N Router?
Please guide me for best results....
Thanks in advance
Koti K
Thanks in advance
Koti K
Hi, I have a question regarding wireless N routers. I currently have a wireless G router, and am looking to upgrade top a N router based on my 2 PCs not being able to DL anything with out affecting the other PC (greatly, 1/4 the dl speed maybe less 400kb/s opposed to 2.2mb/s +). The PCs are NOT wireless, they use a port each. So will an N router deliver a better connection to both or will that always affect 2 PCs no matter what the router. Thanks in advance.
HUAWEI E586 @ http://www.mobile2wifi.co.uk/index.php?main_page=product_info&cPath=1&pr... the latest and hottest mobile wifi for all ref. hope it helps.
It depends on your needs may be the following item can be matched.
http://penta.com.au/index.php?main_page=product_info&cPath=139_146_808&p...
can i use the Tomato firmware of Netgear MNDR3800 n600 on a MNDR3700 N600V2?
ok, i saw your question by chance, probably i can help you
please refer to http://www.modem3g.com/ or
http://www.modem3g.com/huawei-e369-datacard-usb-stick.html
i reside in india use a bsnl broadband connection. i want to buy a wire-less modem with a range of 100-150 meters with good speed. kindly suggest...
I do have DSL (2.2 mbps) connection (Fios not available in my area) at my home. I am told by verizon that I need minimum of 3 mbps for streaming Netflix movies in my basement. Will wireless N router help me to receive signal through Sony google box. Right now I do have no signal or a spotty one.
I do have DSL connection (2.2 mbps speed) at my home (Fios not avilable). I am told by the Verizon that I need a minimum of 3 mps speed to stream Netflix movies in my basement (through Sony Google box). Right now I don't have any signal or a spotty one. Will wirelss N router help me to enhance signal?
N router may enhance the wifi signal, but as far as speeding up the ISP's line to where you could stream netflix, it won't do that, if your line doesn't meet the streaming specs - you'd need to buy more bandwidth from your ISP.
