I have WNR3500L v1
I did install costum firmware yesterday for the first time. Every time I did 30-30-30 to ensure I won't brick it. Finally after few steps I have Tomato flashed and running.
During my last 24 hours I had 3 disconnects, which is weird as I never had any using costum firmware.
Anyway, for the last 10 or so hours it was running fine and without any disconnects.
Then suddenly disconnect happened again and now I can't connect to my router at all.
Tried both wireless and cabel (I can see wifi SSID showing up). No success. 30-30-30 reset didn't solve anything.
Then I turn on router it shows orange lights for a fairly long time (more than 1 minute). Then the Green and blue lights appear showing that everything is up and ready.
well, probably somehow managed to change settings in tomato.. and it wasn't singing ip addresses anymore had to enter on my own before connecting to wifi.
works now
