Hi!
Hope to get some help to access my WNR3500L from you guys!
I uppgraded to the tomato firmware according to this guide
http://www.myopenrouter.com/article/18972/Installation-and-Quick-Review-...
Everything went well. But after changing the IP adress of the router in tomato and a reboot of the router I cannot access by the new IP. WIN 7 finds the network but it says unidentified network.
All this I did connected to the router with cable.
Thanks in advance,
Regards Emelie
Thanks, but how do I connect that way?
The only way I know of is by writing the ip in the address field in my web browser (have tried with both IE and firefox)
Edit:
Ah, I suppose I should add the IP, SM and GW like in step 4 in this guide. Will try.
http://www.myopenrouter.com/article/13859/How-To-Debrick-Your-NETGEAR-WN...
That did the job!
Thanks alot!
//Emelie
