New Toastman Builds
142 posts / 0 new
bigjohn
Random stupid question...
is there any firmware that I can turn one of the LAN ports into a 2nd wan port to have 2 WAN (ISP) connections and load balance them / route preferred traffic / have a backup route?
LilTimmy
Strange. I can't see any
Strange. I can't see any files listed for Toastman's builds on his 4shared page. The directories are all there, but I can't list any files inside them.
I've tried several different browsers & few different OS's. Anyone else able to download latest builds?
Peter Redmer
@LilTimmy--I had just updated
@LilTimmy--I had just updated the WNR3500Lv1 builds to the latest version on 7/16, but when I try to access his 4shared site now, I am seeing the same issue. I'll message him and see what's up.
LilTimmy
Peter Redmer said: @LilTimmy-
Peter Redmer said: @LilTimmy--I had just updated the WNR3500Lv1 builds to the latest version on 7/16, but when I try to access his 4shared site now, I am seeing the same issue. I'll message him and see what's up.
Thx Peter..really appreciate it.
Peter Redmer
According to Toastman, the
According to Toastman, the 4shared server seems to me acting strangely, and he thinks all will be well in a few days. He says it's happened before, but that they address it quickly.
In the meantime, he's uploaded the latest builds here:
http://www.mediafire.com/?88t1vzzcgrphx
Mave
Currently i use a VDSL2 modem
Currently i use a VDSL2 modem/router which i received from my provider, but i want to use my Netgear 3500L v1 again because the wifi performance is way better. But i want to know if i can use IPV6 6RD with the latest TomatoUSB build (1.28.7500.2)?
Aqualung
Quick question: does the
Quick question: does the August 15 E4200 release (1.28.0500.4) contain the updated wireless drivers (namely 5.100.138.20, courtesy ASUS)?
Aqualung
kt_haddock said:
kt_haddock said:
Aqualung said: Quick question: does the August 15 E4200 release (1.28.0500.4) contain the updated wireless drivers (namely 5.100.138.20, courtesy ASUS)?
Yes it does
Thanks. Would be nice to reflect that in the change log though...
Paul J.
Please advise:
Please advise:
I have TomatoUSB running on an E3000 and I love it. While I attend school away from home, I am running an Asus RT-N12B1 and I have tried and tried to flash TomatoUSB. The Asus firmware is interesting but clunky; dd-wrt is good, but not great. Every time I try to flash Tomato, I cannot log into my router.
Perhaps I'm using the wrong version of Tomato. By the way, the B1 version of the N12 has 8MB of flash, so I should be able to use a standard version, right?
Oh--and check out how my processor is reported:
root@DD-WRT:~# ffcat /proc/cpuinfo
system type : Broadcom BCMD144 chip rev 1
processor : 0
cpu model : MIPS 74K V4.9
BogoMIPS : 149.91
wait instruction : no
microsecond timers : yes
tlb_entries : 32
extra interrupt vector : no
hardware watchpoint : yes
ASEs implemented : mips16 dsp
shadow register sets : 1
dcache hits : 2147483648
dcache misses : 4294966784
icache hits : 2147483648
icache misses : 4294967166
instructions : 2147483648
That's not the standard processor for the RT-N12 (or B1), is it?
Paul
OswaldoA
Hi all, I've been using
Hi all, I've been using toastman's version for a few months now and started trying to "play" with the IPv6 tunnel features, using HE tunnel broker site. I created two tunnels, one for my Netgear WNR3500L/U/v2 with toastman's tomato 1.28 and one for my Linksys WRT400N with DD-WRT v24-sp2 (08/07/10) std - build 14896.
Both tunnels works, that is I can ping6/traceroute6 etc, even the test-ipv6.com website show 10/10 in all tests with both tunnels,
but there is something wrong with local bind/named queries when connected to the HE tunnel thru the netgear, I am getting these kind of errors and no resolution whatsoever:
Nov 1 19:02:24 Legolas named[10052]: error (FORMERR) resolving './NS/IN': 192.228.79.201#53
Nov 1 19:02:24 Legolas named[10052]: DNS format error from 192.58.128.30#53 resolving ./NS: non-improving referral
Nov 1 19:02:24 Legolas named[10052]: error (FORMERR) resolving './NS/IN': 192.58.128.30#53
Nov 1 19:02:26 Legolas named[10052]: DNS format error from 192.33.4.12#53 resolving ./NS: non-improving referral
Nov 1 19:02:26 Legolas named[10052]: error (FORMERR) resolving './NS/IN': 192.33.4.12#53
Nov 1 19:02:26 Legolas named[10052]: DNS format error from 193.0.14.129#53 resolving ./NS: non-improving referral
Nov 1 19:02:26 Legolas named[10052]: error (FORMERR) resolving './NS/IN': 193.0.14.129#53
Nov 1 19:02:27 Legolas named[10052]: DNS format error from 202.12.27.33#53 resolving ./NS: non-improving referral
Nov 1 19:02:27 Legolas named[10052]: error (FORMERR) resolving './NS/IN': 202.12.27.33#53
and it only happens when I use the root hints directly, if I use a forwarder, the named successfully does the name resolution.
when I switch to the linksys, with dd-wrt, the named does not logs any errors and is able to resolve the same hosts, in similar conditions, that is, using root hints, no forwarder.
I tried with an MTU of 1480, 1460 and now it is at 1280 as the dd-wrt and still getting those errors and no resolving when using the netgear with toasman's tomatousb... dont know what else to look at.
btw, in toastman's I opened ports 53 and 41 tcp , first without target IP, which caused get several warnings for blocking from the test-ipv6.com, but when directed to my specific IPv6 address, it all worked fine. I opened port 41 for all crossing traffic with ip6tables.
I dont know where else to post this request for help, so if this is the wrong place, please point me to the right direction.
have anyone faced this situation? where should I start digging ?
thanks in advance.
Aqualung
Guys, I just noticed that my
Guys, I just noticed that my 5GHz band is not working. I'm on a Linksys E4200 w/Toastman Tomato 1.28.0500.5 (tomato-E4200USB-NVRAM60K-1.28.0500.5MIPSR2Toastman-RT-N-VPN). Can anyone confirm?
haloreach277
Will there be a build of
Will there be a build of tomato made for the Netgear R6300 would love to use it prefer it over stock firmware dd-wrt or openwrt
Mave
Is there an easy way to
Is there an easy way to enable a guest wifi network using multiple ssid? I can't find any configuration options in the GUI, but i do see mentions about it in the changelog. I'm using the latest VPN build (1.28.7501.2).
Paul J.
I've set up a virtual
I've set up a virtual wireless interface for guest access (as a test), but the guest network could ping and see my primary (secured) network.
I tried IP Isolation with no success.
If you figure it out, please post your procedure / technique here.
-Paul
Mave
kt_haddock said: Yes it is.
kt_haddock said: Yes it is. Have you looked under Virtual Wireless => Virtual Wireless Interfaces ?
There is no Virtual Wireless option, i googled a bit and it should be under 'Advanced' but it isn't there.
Mave
kt_haddock said: Well then
kt_haddock said: Well then erase NVARAM and reconfigure by hand. I'm sure it's there. I'm using 0501.2 and it's there.
I already erased the NVRAM when i flashed, believe me, it aint there. :P
Toastman
September 17 2013 - 1.28.7503
September 17 2013 - 1.28.7503 and variants
( Beta release - only due to ongoing changes to ipv6 handling using dnsmasq! )
  • add pairNIC DDNS service Implement ipt_account fixes for Kernel 2.6.36
  • added "String" module for ip6tables bridge: avoid ethtool on non running interface.
  • bridge: respect RFC2863 operational state.
  • Access Restriction: Check chain blank before delete. Patch from EasyTomato trunk.
  • Added extrarules to iptables to get UDP request. (https://dev.openwrt.org/ticket/155) EasyTomato patches
  • Busybox: Upgrade to 1.21.1
  • SSID: Respect ASCII character label
  • Correct access restrictions save/delete bug with some browsers
  • ipt_webmon_info haddifferent define in kernel and iptables.
  • Busybox 1.21.1 update
  • dnsmasq: Update Sept 13,2013 to 2.67test14
  • VLAN: Correct mapping Netgear 3500L V2 allowing tagging now
WARNING - DHCP IS DISABLED BY DEFAULT. DON'T FORGET TO TURN IT ON IF YOU NEED IT.
LilTimmy
Nice! Thanks
Nice! Thanks
haloreach277
Any chance the R6300 on
Any chance the R6300 on r6300v2 will be supported would like to try on my router if supported
Toastman
We are working on the newer
We are working on the newer routers, there have been considerasble changes to the wirless section and it isn't 100% completed yet.
Mave
Hey Toastman, i have some
Hey Toastman, i have some instability troubles with the latest 1.28.7505.x firmwares on my Netgear WNR3500L. My router randomly reboots and i can't find why because the logs are always gone after a reboot. I already cleared the nvram to rule out any problems that might be caused by flashing without clearing it. So far no luck, maybe you can look into this? Or give me tips how i can see where the router crashes on?
