kingkong-nv32k-broadcom.bin
2 posts / 0 new
Blujay
Hi guys,
Can you tell me if kingkong-nv32k-broadcom.bin is compatible with my router - wnr3500L
Why is this file so large? (10MB) compared to usb-ftp-samba3-dlna-nv32k-broadcom.bin
What's the differences between them?
jmwhite
Anything above 7.4 MB can't
Anything above 7.4 MB can't fit into the flash space on the WNR3500L V1, so no don't attempt to flash it, it can't fit and you'll get a brick.
That's not to say you should flash something based on filesize alone.. Just something to note.
