hello,
I just read your tutorial "How to Install Tomato Firmware on NETGEAR WNR3500Lv2", and if I understand, I have just to install the "Tomato" firmware as if I installed a Netgear firmware after of course restore default configuration.
Between these 3 firmwares, which would you recommend
- Tomato by Shibby for WNR3500Lv2 093-AIO (All In One)
- Toastman's Tomato Firmware for WNR3500Lv2
- Tomato Firmware for NETGEAR WNR3500Lv2 Initial Release + Src
I guess the one developed by Shibby is more successful.
Excuse my bad English (I'm French ...)
Thank you very much in advance
Sincerely,
which firmware do you recommend
Mon, 07/16/2012 - 3:59am
#1
"Tomato Firmware for NETGEAR WNR3500Lv2 Initial Release + Src" firmware was initial release, you will get the basic features in it.
While shibby's and Tostmans's firmwares are populated with more features. Each of these build contains a list of features included. Select any of these builds as per your requirement.
