Posted in wrong forum
So, after installing tomato's firmware (tomato-Netgear-3500Lv2-K26USB-1.28.RT-N5x--093-AIO.chk) i can't get acces to 192.168.1.2. I read about this DHCP thingy, and set Static IP to 192.168.1.10, mask to 255.255.255.0 and gateway to 192.168.1.1.
All lights like Wi-Fi, Lan are flashing.
After i turn on router i can ping it for about 5 sec, but then still no response
Feeling very bad for my incompetent hands, just bought router two days ago and looks like i bricked it
did some research
after powering on, router is asking for vmlinuz file (firmware) via tftp, so i put it and... nothing happened, still stuck
Hard resets dont work ( tried about 20 times)
As per I have understood from your post you are unable to connect to your router.
But I couldn't understand why are you trying to connect to 192.168.1.2 ?
Generally router ip is set to 192.168.1.1.
Ah, i mistyped, sure i tried to connect to 192.168.1.1.
But thank you for thre reply
