I had 2 NetGear WNR3500Lv2 with Tomato (beta) Version 1.28. I installed them in 2010, but each router broked. I bought a new one and I thought I search a new tomato version. First I upgraded Netgear firmware to DD-WRT, because old time it was the first step. After I found Shibby's works, so I try upgrade it to 108-AIO (tomato-Netgear-3500Lv2-K26USB-1.28.RT-N5x—108-AIO).
First try I got a message (upgrade was successfull) but the router power led blinking in green. So I did hard reset (30-30-30), but nothing changed. I did the TFTP method, and upload back DD-WRT. After read some posts and found 2 posts, that some cases first install not perfect. I tried again, but the result some as before.
After I tried tomato-Netgear-3500Lv2-K26USB-1.28.RT-N5x—107-AIO, but the resault is same as before. :(
What is the problem?
Model: WNR3500Lv2 (128 MB NAND FLASH RAM)
I couldn't wait the helpful answer so I downgraded DD-WRT to original NetGear firmware (WNR3500Lv2-V1.2.0.16_40.0.66). I tried again tomato-Netgear-3500Lv2-K26USB-1.28.RT-N5x--108-AIO.chk. It was succesful. So the starter firmware is important!!!
