Useing the guides found from the wiki on setting up ipv6 with dynamic ipv4, it says i have to make a file with telnet or SSH /jffs/etc/config/6to4.wanup:
I have tryed many ways of doing this but apparently im getting it wrong as i recieve the errors of cannot cd to /config. What is the command line i need to put this file onto where it needs to be?
What firmware are you using? I just installed Shibby AIO and there is no /jffs/etc/ and the /jffs directory is write only. There are some other threads about /jffs here which might be useful.
That said, and assuming you have a writable file system, here is how I would do it:
scp 6to4.wanup [email protected]:/jffs/etc/config
Substitute whatever IP you are using for this router.
http://blog.dev001.net/post/33503557513/dd-wrt-ipv6-and-6to4-with-dynami...
That is the guide i am speaking of and this is on DD-WRT kong 20500
I'm just trying to understand this myself, but there seems to be a problem with jffs. Perhaps this thread is informative.
My previous posts got deleted but the answer to your title question might be of interest to others searching these forums so here it is again:
$ scp 6to4.wanup [email protected]:/jffs/etc/config
That is how you put a file by the name 6to4.wanup in /jffs/etc/config. Of course the IP might be different for you.
That said, it does look like there is some other problem. I don't understand it yet but it looks like there are issues with mounting jffs on some routers. A search for "jffs" on these forums will bring up an interesting thread.
PS: I won't post the actual link because I think that's why my previous post got deleted. :)
Thank you so very much for the information. I will look further into the other threads you mention and will mess around with this a bit more. My interest was to give DD-WRT a run but without that file (or i am assumeing since it isnt working) it just will not do the tunnel.
this is just a temp fix as i will be getting a modem which supports ipv6 soon, i just have to find where i can buy one with a telephony part since i have their phone service as well.
thanks for great guide charles. It help me to.
