Hi!
I currently using Kong's r20780 build for my WNR3500L v1.
There it is possible to enter a custom configuration for samba file sharing.
If I upgrade to a higher Kong build there is no more possibility to enter a custom configuration.
Got this option removed or do I miss something?
Because I have some special shares with sub folder they are not possible with the normal configuration I will need this custom configuration.
Is there also a chance to get a custom configuration field for ProFTP?
I have some special commands like "AllowStoreRestart" to enable append/resume of a ftp upload. Like now I stop proftp, delete the conf file and create a new one, and restart proftp on every restart of the router.
Hi, your suggestions are all good ideas, right now I am using Proftpd by using OPKG. I am not using the built-in proftpd that comes with the builds. If you setup OPKG and then install proftpd along with it you will then be able to configure all the settings you want.
