Debricking
10 posts / 0 new
MReptile
MReptile's picture
Debricking
Is there already a method to recover a bricked wndr 3800?
I like the guides that show how to install the open-WRT Firmware. But what can we do when it brick.
Is a working method already known?
Greetings
MReptile
Subhra
Subhra's picture
Till now I know only one one
Till now I know only one one method to debrick WNDR3800, and it is using serial console. If you have the one, I can provide you the detailed procedure.
Brandon C
Brandon C's picture
Subhra said: Till now I know
Subhra said: Till now I know only one one method to debrick WNDR3800, and it is using serial console. If you have the one, I can provide you the detailed procedure.
Do you have some pics of the connectors with details of each? I will be getting one next week and setting up a serial cable for it.
Subhra
Subhra's picture
The following pictures
The following pictures explain the pin connetions.  You can use the same serial cable as that of the WNR3500L.
It is just for remainder that whenever you break the seal, the warranty will not be valid anymore, so be sure before breaking the seal.
Brandon C
Brandon C's picture
Perfect thanks. I will post
Perfect thanks. I will post some articles on it once I have had a chance to mess with it.
locksmith
locksmith's picture
Great post and highly
Great post and highly informative too.
[url=http://www.sevenlocksandkeys.com/]Lexington Locksmith[/url]
[url=http://www.24by7locksolutions.com/]Locksmith Medford MA[/url]
[url=http://www.1a1lockout.com/]Locksmith Franklin MA[/url]
[url=http://www.sharpinma.com/]Watertown Locksmith[/url]
locksmith
locksmith's picture
Nice post.Thanks for sharing.
<a href="http://www.sevenlocksandkeys.com/">Lexington Locksmith</a><br />
<a href="http://www.24by7locksolutions.com/">Locksmith Medford MA</a><br />
<a href="http://www.1a1lockout.com/">Locksmith Franklin MA</a><br />
<a href="http://www.sharpinma.com/">Watertown Locksmith</a>
anhost
anhost's picture
DId anybody found it easy way
DId anybody found it easy way to debricking WNDR3800 without serial cable, after using Openwrt?
I realy need it.
Sorry for my English.
Subhra
Subhra's picture
Till now I know only the
Till now I know only the serial console method to debrick WNDR3800. I want to have the knowledge how did you bricked it with OpenWRT ?? What is the current status of your router ???
prodigy999
prodigy999's picture
What is the method to debrick
What is the method to debrick the WNDR3800? Where can i find it?
I already have a USB-TTL Cable.
Please help.
