A Clean release of DD-WRT or Open-WRT for the R6300 v.1
10 posts / 0 new
webdevii
webdevii's picture
I just recently purchased the infamous Netgear R6300 Dual Band Router, I totally love it, however after seeing the features that the XXX-WRT firmwares support above and beyond what Netgear offers I would like to run my Router on the WRT firmware.  Now as I was looking through the blogs and comments I noticed there were  a lot of bugs in the latest versions for the R6300.  What I am interested in knowing, is there going to be a Stable, Clean version ever for the Netgear R6300 Version 1.  As I do not want to really buy another R6300 v2. Or for that matter another brand that XXX-WRT does support bug free.
My network configuration is as follows:
1. ISP  =  Verizon FiOS, Specially modded by Verizon and myself to run Ethernet over Ethernet instead of Ethernet over MoCA Thus being able to use my own router.
2. I have Internet, Video & Landline service via Verizon, the only thing the
    Verizon Actiontec is even there for is to manage the Video, I have my own router
     plugged directly to the ONT thus bypassing the Actiontec for serving up the web.
3. I run a Qnap NAS on Dual RJ45's and Cat-6 Cabling.  I have 6 Devices that run off of the
    5 Ghz Wireless at blazing fast speeds
4. I run 3 Desktops on the Wired side (1, Mac Mini - 1, i7 Gaming Power system, 1 All in
    One for my day to day business needs.
I get excellent Thruput on both the 2.4 Ghz and 5 Ghz Wireless bands.
I run a network attached security system on one Wired connection.
So there you have it......
Any assistance would be greatly appreciated, so with that said................
Thank you all in advance for any help you can offer
Respectfully
Dev,
webdevii
webdevii's picture
Ok, I took the leap and
Ok, I took the leap and flashed my new R6300 v2 Smart Router with the latest firmware available on this site. It works perfectly. No Brick no Problems!!
m4p
m4p's picture
webdevii said: Ok, I took the
webdevii said: Ok, I took the leap and flashed my new R6300 v2 Smart Router with the latest firmware available on this site. It works perfectly. No Brick no Problems!!
I'm confused.  Didn't you say you had the v1 of the R6300?  Do you know if there's a stable DD-WRT for it?  Thanks.
webdevii
webdevii's picture
At one time I hd found a
At one time I hd found a version fort v1, however I think it became too buggy and it was pulled down. The v2 is th only way to go other than the ASUS RT-AC66u which imo i a much better quality router. and ASUS supports OPN-WRT
I ended up flashing my Netgear v2's back to OEM FW and they also run fine.
From what I have been hearing that DD-WRT is shying away from netgear and will eventually not make a release for any of the new a/c/ routers.
Sorry for the confusion in the beginning.
Dev
Kong
Kong's picture
@webdvii,
@webdvii,
I think you are misinformed .
The R6300 V1 / WNDR 4500 V1/V2 are officially supported by DD-WRT.
The R6300 V2 will be supported soon. I already added detection code for it. Once I receive a R6300 V2 I'll test and complete the port.
For some updated info on support status you can look at the DD-WRT wiki:
http://www.dd-wrt.com/wiki/index.php/Supported_Devices
P.S. There are builds available on this site, that already support the R6300 V2, these are not unofficial dd-wrt builds and may have a few more bugs and incomplete incompatible upgrade routines.
exlaval
exlaval's picture
web
web
can i use the v2 FW with my v1 (i presume it's v1 cuz of the usb 2 and not 3 according to specs)
if yes do i need ONLY one file or 2 as in the other v1 setup page
quite confused, truly
thanks
asmartin
asmartin's picture
Hi.
Hi.
Thanks a lot for all effort to make this pretty DD-WRT distribution.
I just want to use R6300 for Fiber Optic access through an ONU, so it needs support for VLAN tagging.
Does your particular distribtion support VLAN tagging?, maybe v2 too?
Thanks in advance.
Alex
Subhra
Subhra's picture
VLAN tagging is a basic
VLAN tagging is a basic feature of dd-wrt firmware. So, should be available in all dd-wrt firmwares. But I haven't tested the feature for R6300.
pistoleroX
pistoleroX's picture
I also have this router(v1)
I also have this router(v1) and the dd-wrt works fine for it. However I'd really like to run OpenWRT on it but haven't been able to yet.
Thing is, OpenWRT doesn't support this officially however people have made it work on the v1, allegedly. v2 isn't supported though, for some reason.
My question is; since the openwrt forums/IRC aren't being super helpful about this, were any of you here able to run OpenWRT on the NETGEAR R6300 v1?
Subhra
Subhra's picture
As per my knowledge is
As per my knowledge is concerned, still now there is no OpenWRT firmware for R6300v1 in this site as well as in OpenWRT site.
