Channel Selection not applying.
5 posts / 0 new
nissank
nissank's picture
Did a quick search but nothing came up.
In my wireless configuration, I can't seem to change/apply the wireless channel. I set it to auto, click apply, selects a channel automatically. However when I want to manually select channel 11, click apply and it always default back to channel 6 (one of the worst ones)
Anyone else seen this before? I'm fine with leaving it auto but it doesn't always select channel 11.
nissank
nissank's picture
No one has any input?
Subhra
Subhra's picture
Which firmware are you using
Which firmware are you using ??
Mike574
Mike574's picture
Ooops, I just made a post
Ooops, I just made a post with this exact same situation, I'm also stuck on channel 6. What firmware are you on? I'm on Shibby's 1.28.
Guillaume
Guillaume's picture
I am in the exact same
I am in the exact same situation with firmware stdkong(SVN revision 20500M)...
