- Working the EXACT same 11 months 2 days ago
I am not being able to understand your requirement.
All routers come with basic Firewall support. Which firewall feature do you need??
I have just bought and configured the R7000 with the latest Kong flash. I have found this site helpful in the past
http://www.dd-wrt.com/wiki/index.php/Iptables_command
If you look at the command carfully you can mix and match them to suit your needs
This is a very good tutorial about iptables. Advanced users will find great interest in it. While normal users may use dd-wrt WebUI for easy configuration of firewall features. Most of the basic firewall configurations can be done through dd-wrt WebUI.
