Hi guys.
So I have some problems with my router.
I upgraded it from stock using the DD-WRT found here.
http://www.myopenrouter.com/download/19806/DD-WRT-Kong-Mod-USB-FTP-miniDLNA-Samba3-WNR3500Lv1/
It was all working fine, exept a weird problem with wlan.
I could not get the router to broadcast the ssid, and I could not connect to wlan by manually searching for the ssid either.
The only way I could connect to wlan was by setting up a virtual network with a separate ssid. That way I could find the network by ssid.
So I figured lets give Tomato a try. This version :
http://www.myopenrouter.com/download/26575/Toastman-s-Tomato-Firmware-for-WNR3500Lv1-w-USB-Ext/
Now im sitting here with a router that seems pretty dead.
Well, almost that is. I can still use it connected by cable, i have another router that is doing the dhcp job. Everything works fine like this. It even broadcast a wlan named "wireless" that seems to be working fine.
But I can´t figure out what the ip of the router is. So I have no way to try managing it.
I have done a scan with Ip Scanner, but I can´t find it.
Any tips?
Do a 30-30-30 reset of the router. The router should default to 192.168.1.1 - Tomato defaults to DHCP disabled, so set your PC to a Static IP in that subnet and try again.
