Is anyone going to develop the firmware for this model?
Firmware for R6200v2 is avaliable in this link.
When I download that one, the only file that I get in the .ZIP file is a .chk "Recovered File Fragment" and the router wont let me install that. :)
The Above mentioned link provides,
- A zip file containing the firmware (dd-wrt.v24-K26_R6200v2_22-July-2013.chk) for flash your router.
- A link ("Link to Source") to download the dd-wrt source for R6200v2. You may use this source to build the firmware at your own.
Which router model are you using, R6200 or R6200v2 ??
The above firmware is meant for router model R6200v2.
I have the R6200. I'm not a developer and I really with that I was. It would make things like this easier. :)
R6200 and R6200v2 are different router model, so they need different firmware.
You shouldn't try to upload firmware meant for different router model on your router. Such attempt may damage your router.
Link for DD-WRT firmware for R6200v2 is now corrected. People can find the dd-wrt firmware for R6200v2 in "DD-WRT -> R6200/R6200v2" tab.
The netgear firmware is really basic. Great that dd-wrt Kong is developing and releasing actively.
I hear from shibby that he is working on an ARM firmware that I hope will work for the 6300v2.
New dd-wrt firmware for R6200v2 with linux-3.10 kernel is available in this link.
Here is a link to Kong's version of DD-wrt for the R6300v2
This discussion is concerned about R6200 and R6200v2 which are different router model from R6300v2.
You can chek this link to get the difference.
Hi all,
DD-WRT firmware for R6200(v1) is available now ... Links are: Firmware, Source Code.
Users of R6200v1 are requested to share there experience "Discussion" section of R6200v1 rather than posting in some other place. It will help to track status of the firmware.
Is firmware for the R6200v2 still being developed? Also is there any current general documentation for this base release? Thanks...
Links realting R6200v2 are listed below,
* Latest dd-wrt firmware for R6200v2
* Latest dd-wrt source code for R6200v2
* How to Update your Netgear R6200v2 to DD-WRT Open Source Firmware
