Differences Between R6300 and R6200 V1 and V2 models
Have you been wondering what the differences between the V1 & V2 versions of the R6200 and R6300 models are?
Here is a quick cheat sheet that provides the specifications.
R6300
R6200
V1
V2
V1
V2
CPU
BCM4706
600MHz Single Core
BCM4708
800MHz
Dual Core
BCM 4718
500MHz Single Core
BCM47081
800MHz Single Core
USB Ports
2x USB2.0
1x USB3.0
1x USB2.0
1x USB2.0
1x USB3.0
Memory
128MB
256MB
128MB
256MB
There are some nice improvements in the V2 models across the board.
Tags:
Officer Dibble
Officer Dibble's picture
One thing you forgot. The
One thing you forgot. The R6300 V2 also has 128MB of flash memory as well as the 256MB of ram shown here.
Subhra
Subhra's picture
Very handy material, thanks
Very handy material, thanks for posting this.
dbx8
dbx8's picture
Is there an easy way to
Is there an easy way to determine which model I have.
Elmanny90
Elmanny90's picture
dbx8 - On the 6300, just look
dbx8 - On the 6300, just look at the USB ports, if both of them are black, they are both 2.0 which makes it a v1, 3.0 ports are blue. Same thing with the 6200 if that is the one you have. Not the most technical way of knowing, but it is the easiest without having to go into the details of it through software.
Elmanny90
Elmanny90's picture
