Build 23350 15. Jan 2014.
7 posts / 0 new
Accid
These are the features I have tested and are using
Vlans working
QOS working
Wireless 2.4 will work at full speeds only if Beamforming is disabled, if enabled the speed is limited to 2 – 2.5mbps
WDS is working when linked with a Linksys E900
Keep Alive - Schedule Reboot working
Universal Plug and Play (UPnP) working
USB Support on both ports working (had to reboot router) testing the read right speeds
Samba Server working so far
Kong
In my tests I also had
In my tests I also had problems with wireless performance with beamforming enabled along with an Intel 6300 agn.
With the other wireless clients I tested e.g. Netgear A6200, beamforming works well.
I also got reports from others, that the the Intel 6250 shows the same behaviour. So far I only know of problems with Intel Adapters and wireless.
octogon
Accid said:
Accid said:
These are the features I have tested and are using Vlans working QOS working Wireless 2.4 will work at full speeds only if Beamforming is disabled, if enabled the speed is limited to 2 – 2.5mbps WDS is working when linked with a Linksys E900 Keep Alive - Schedule Reboot working Universal Plug and Play (UPnP) working USB Support on both ports working (had to reboot router) testing the read right speeds Samba Server working so far
Hi , where can i download the latest firmware for Newtgear R7000 , build 23350, thanks in advance.
Subhra
First use the Initial flash
First use the Initial flash for R7000 and then Build 23350
Accid
I have noticed the Linksys
I have noticed the Linksys E900 freezing, I have had to set the automatic reboot time on the E900 to 2 hours.
I have tested the copy speed on the network while connected to the Linksys E900 on WDS, its under a megabyte. Have to try it when connected to the R7000 only.
My wireless is set to NG, channel 4 and 20.
The read write speeds from a USB 3 hard drive are between 20-29 Mbps, not bad.
Yesterday I noticed I had no wireless access(the devices were not getting an IP)on the BULLET-M2-HP or my private network but I tried it through the wired ports and I had internet.
I think I have to many services running on the device. Will remove and retest.
Along with the services I have listed I have also added access restrictions for a specific MAC address.
pth
I'm currently running (01/03
I'm currently running (01/03/14) kongac - build 23270M. Can I upgrade directly to 23350 using the Firmware Upgrade page?
Kong
Yes and since there was no
Yes and since there was no change in nvram params you don't need to reset, just flash the new build.
