Hello fellow R7000 Users,
I just picked up a R7000 yesterday to replace a much older Netgear router. In the past I have read up on the benifits of flashing 3rd party firmware and DD-WRT seemed to be the clear winner. However, there was very little support for my old router and I never actually pulled the trigger and tried it out. That being said, I have spent countless hours learning about home networking (mostly through trial & error and breaking stuff).
After reading up on the release notes and change-logs, it looks like Kong's build is the clear winner. I'm planning to give it a go when I get home today. That being said, I thougt I would ask around for some general tips before doing it. I also had a few questions that I was hoping someone might have the answer to.
I understand that flashing DD-WRT is a simple process, especially when it is supported by Netgear. However I did not see any specific guides for how-tos with the R7000. After reading up on the ones available, my plan is as follows
- Download Kong 23430
- Back up stock router settings and save on computer
- Hardwire laptop
- Flash Kong as manual upgrade
- Configure and save new settings
I understand that reverting to stock should be as simple as downloading & flashing stock firmware then reloading settings.
In addition, has anyone noticed any disadvantages to DD-WRT such as losing the built in Up/Down QOS functionality that Netgear keeps updated or other issues?
I know this is a long post and I appreciate those of you who stuck with it long enough to get here. Those who didn't:
TLDR:
Does anyone have any advice for someone who will be flashing DD-WRT for the first time?
Before flashing go through the README for flashing instruction.
I think your approach is good. I flashed the box a few times now and it seems to work fine.
It is always recommended to go through the flashing instruction of concerned firmware. Good to know that things are working at your end.
