Where is the initial flash for the R6300v2? I've checked at the hyperlink below but nothing stands out as the initial firmware for the R6300v2. Could it be the beta?
http://www.myopenrouter.com/download/list?cat=91
That is the initial flash:
http://www.myopenrouter.com/download/52688/DD-WRT-K3-for-NETGEAR-R6300v2...
since on the R6250/R6300V2/R7000 it is possible to flash the full build and it is not required to flash a stripped down build.
And i get a reply from the man himself. Thank you Kong!
Hi Kong, does this version support noCatSplash?
