Folks - can someone clarify to newbie FW upgrade path for R7000?
I found this link: http://desipro.de/ddwrt/K3-AC-Arm/
I see the latest is 24045, I grab file named dd-wrt.v24-K3_AC_ARM_BT_NEWD.bin and try to flash it on my router (currently I am runnig 23900m)
Update failed. The router is alive :)
Before I brick my new router, can some please suggest which what and how?
Thanks in advance1
Never mind - managed to flash dd-wrt.v24-K3_AC_ARM_STD_NEWD.bin...
Hi There,
I would you the OLD version, this contains the old WiFi drivers I believe. This was more robust for me.
Thanks - even this one seems OK-ish, but I will try old WiFi drivers version too
One nice thing about Kong's firmware - I can upgrade firmware, and all my settings (including overclocking!) stay intact - no need to reset the router to defaut settings...
