- R8000P would be grate to see. 2 years 1 month ago
- Have a R8000 but ordered a 2 years 1 month ago
http://www.bufferbloat.net/
IP address: 192.168.1.2
Subnet mask: 255.255.255.0
Default gateway: 192.168.1.1
Click OK button
HTH - Good luck!
Guys, I need serious help.
You can find help here:
Base
Hey Umesh,
Regards Base
Ip adress you put 192.168.1.2
Subnet mask 255.255.255.0
gateway 192.168.1.1
Hey,
Hey Umesh,
Regards Base
gateway 192.168.1.1
