You are here
  1. Home
  2. » Forums
R6200v2 config
6 posts / 0 new
rublez
rublez's picture
R6200v2 config
Can you all help me configuring my R6200v2 router with DD-WRT? I had a Linksys 160N for some years and it was fully tunned, but now I can't, or I don't know how to, make higher channels (+100) to appear. I think that it's the reason why connection speed don't achieve more than 400mbps compared  to 866 when using original firmware. I  tried to configure using fixed AC or 5gz, 40 or 80mhz, but nothing worked.
Anther question is about setting router's mW power. Can I set all the 700mW that had been stated by Netgear in the product box?
Thank you.
Subhra
Subhra's picture
I would suggest you to
I would suggest you to propoerly configure your wireless. You make read this tutorial for your reference.
rublez
rublez's picture
Thank you, I'll try it now.
rublez
rublez's picture
rublez said: Thank you, I'll
rublez said: Thank you, I'll try it now.
It worked, but I think the problem was with the 'region'. As I'm in brazil, I had changed region to 'south america' so upper channels for 5ghz wasn't appearing. So I change it back to 'United States' and high speed connection (866.7) and transfers are enabled again.
In my case 'implicit beamforming' was necessary too.
Below, in the embedded image, are my configuration.
Configuration
Subhra
Subhra's picture
Nice to hear that things are
Nice to hear that things are working at your site. Is 'implicit beamforming' working for you ??
rublez
rublez's picture
Yes, it is working. In my
Yes, it is working. In my notebook I've got a Intel 7260ac, and I tried some configurations and, when I used 'explicit beamforming', connection speed wasn't higher than 300mbps. I read some articles about it, that 'explicit' is better but for 7260ac it isn't working. In 7260ac specs or Intel's related articles there's nothing referring to beamforming (at least I didn't found any).
