Where is the initial flash for R6300v2
4 posts / 0 new
bblades262
bblades262's picture
Where is the initial flash for the R6300v2? I've checked at the hyperlink below but nothing stands out as the initial firmware for the R6300v2.  Could it be the beta?
http://www.myopenrouter.com/download/list?cat=91
Kong
Kong's picture
That is the initial flash:
http://www.myopenrouter.com/download/52688/DD-WRT-K3-for-NETGEAR-R6300v2...
since on the R6250/R6300V2/R7000 it is possible to flash the full build and it is not required to flash a stripped down build.
bblades262
And i get a reply from the
And i get a reply from the man himself. Thank you Kong!
viken
viken's picture
Hi Kong, does this version
Hi Kong, does this version support noCatSplash?
