I havent used DD-WRT since the problems started with the 5ghz band at rev 24500M so when I saw that Kong had fixed the issue I loaded 24800M. Everything looks good so far on 24800M with the exception of UPNP. I have a NAS drive that I usually connect to remotely via the WAN port. The NAS drive uses UPNP to forward the appropriate port from the WAN to the LAN. However I see that nothing is showing up in the UPNP table as viewed from the router NAT/QOS pages since loading 24800M. I am getting around this the old fashioned way (Manual port forwarding) but as I have several other devices on my network that use UPNP it sure would be nice to get this working again. Any ideas?
Nobody else using UPnP? Any ideas what may cause this to stop working?
Ok - So Kong fixed this in the 24850M build. (Even though he didn't list it in the change log.) Thanks Kong!
