I'm not sure what I am doing wrong.
I followed the directions to unbrick my Netgear R6300 and was able to download and update the latest Netgear image.
everything was great, but I am a curious guy.
I flashed the recomended DD-WRT for the 6300 and it installed. As per the recomendation I set up the security for the wirless and went to set the UPnp to recomended settings but there is no page that comes up. Just a blank page (white). I can go backarrow, I can access all other tabs on the DD-WRT interface. Only this one page is a problem as far as I know.
I can not surf the web wired or wirelessly.
I have rebooted the router many times.
I have performed several 30, 30, 30's More then 3 times
I downloaded a secound DD-WRT file in case the original one had become couruped and gone back through all of the above.
I am lost what suggestions do you have.
I am excited to figure this out I don't know what I am missing.
Which dd-wrt build have you installed?
I have almost the same problem. A blank page on UPnP. But I do can surf without problems.
Firmware: DD-WRT v24-sp2 (04/14/14) giga
Hey guys,
I have the same issue today with a version of DD-WRT. I am using the following:
dd-wrt.v24-K3_R6300
so far this seems like the only issue I can see.
I had the same issue as well with the UPnP section with the most recent build. I went to the older Kong build from October 2013 and it seems to be fine.
