Hi everyone
Can anyone tell me which is the latest stable version of Kong Firmware for R7000?
This information is found all over these forums, but I'll be nice today. Kong puts his builds here:
http://desipro.de/ddwrt/K3-AC-Arm/?C=M;O=D
That's sorted by date. You can also check the changelog in the same folder for the latest as well.
Hi
Sorry for not explaining myself.
I am currently using build 24800M on my Netgear R7000 and 1450.
I have found this build to be most stable.
Currently I have 4 Vlans, DDNS, Port forwarding, PPTP VPN Server, FTP Server, Samba Server, WAN Access Access Policy to block torrents and Quality Of Service all working perfectly from each router.
I was wondering if anyone of there was any other stable build after the 24800M. I tried the 24865M build and found it to be buggy. I usually upgrade to every latest build but stopped after the 24800M.
Well I'm running his latest with no issues, but admittedly I don't use a lot of the extra features like minidlna or vlan, that said it's stable for me.
Actually I'm surprised you don't just run the latest, Kong has done a lot of fixes and package updates.
I am not sure why it is a surprise, I rolled back to 24865M because the latest one was constantly crashing, like once/twice a day.
