Hi guys!
I've flashed DD-WRT onto my R7000 and have Private Internet Access set up with the OpenVPN client
Can anybody point me to a decent guide on setting up IPTABLES so that I can do a couple of port forwards?
Right now, I've got my network split between two routers, the R7000 connected to another one, which is connected to the Internet.
I'm using a static route and a WINS server to handle communication between devices on the two subnets.
That is working, but I'd like to have everything behind the VPN and then connect to the services I need using port forwarding.
I am new to DD-WRT, but I'm an experienced software engineer and can figure things out if I have a good reference or starting point.
After Googling a few dozen times, I'm thinking that I am not using the correct terminology or don't understand a key concept.
Any advice or comments will be greatly appreciated (sarcasm is welcome).
Doug - I just purchased an R7000 as well. I've managed to get DD-WRT on it, but I've yet to have any success installing other packages via ipkg. Have you?
I haven't even tried. My current setup is working for me flawlessly, so I haven't wanted to experiment.
