hi,
I installed the version v24 in my R8000. I have a 1 terabyte disk NTFS and I can not access ftp mode or in windows mode, as I do the configuration. I've tried everything I could. I am a professional systems. There should be a more friendly firmware.
Thank you very much,Christian
If possible you may try the following cases:
1. Use a NTFS disk with size less than 1 TB (say 8GB).
2. Use a FAT32 or EXT4 disk with size 1 TB(terabyte).
I did not find any problem with 8 GB NTFS disk. So, I need to know whether the issue is related to NTFS File System or Disk size with 1 Terabyte and more.
I will be waiting for your response.
First, thank you by your response. I can to solve the problema with NTFS disc of 1TB.
Thanks again.
Christian
Well thats fine....
Thanks for your feedback.
But could you please say how you solved the issue?
Well, i can to confirm that problem was of configuration. Not a problem of firmware.
Thanks again!
Christian
Thanks again.
Christian
Well thats fine....
Thanks again!
Christian
