Bittorrent transmission daemon
9 posts / 0 new
christianwis
christianwis's picture
Hi all
How i can to configure Bittorrent transmission daemon ? I cant to do work ...
Thanks you
Christian
christianwis
anybody can to tell me, how
anybody can to tell me, how to see the process of bittorrent on the router if running ?
I cannt do work
thanks in advances,
Christian
Sayan Mukherjee
Sayan Mukherjee's picture
Steps to configure Bit
Steps to configure Bit Torrent:
1. Set up your WAN Connection so that you can access the internet.
2. In router web interface, go to Administration > Management > JFFS2 Support. Click on Enable Radio Button in JFFS2 option. Click on Save. Then Apply Settings.
3. In router web interface, go to Administration > Management > JFFS2 Support. Click on Enable Radio Button in Clean JFFS2 option. Then Apply Settings (Do not click on Save). Wait for a minute.
4. In router web interface, go to Services > NAS > Bittorrent. Click on Enable Radio Button in Transmission Daemon option. Click on Save > Apply Settings.
The following service must be seen if you login to the router with Telnet and fire the command "ps" :
"transmissiond --config-dir /jffs/transmission"
(You can definitely change the transmission directory. In that case you will see the specified path instead of /jffs/transmission above, but I have done with /jffs/transmission).
Now you can access the transmission page using the following URL:
http://192.168.1.1:9091/transmission/web/ (where 192.168.1.1 is my router IP).
Please try these. I will be waiting for your response.
christianwis
Sayan Mukherjee said: Steps to configure Bit Torrent: 1. Set up your WAN Connection so that you can access the internet. 2. In router web interface, go to Administration > Management > JFFS2 Support. Click on Enable Radio Button in JFFS2 option. Click on Save. Then Apply Settings. 3. In router web interface, go to Administration > Management > JFFS2 Support. Click on Enable Radio Button in Clean JFFS2 option. Then Apply Settings (Do not click on Save). Wait for a minute. 4. In router web interface, go to Services > NAS > Bittorrent. Click on Enable Radio Button in Transmission Daemon option. Click on Save > Apply Settings. The following service must be seen if you login to the router with Telnet and fire the command "ps" : "transmissiond --config-dir /jffs/transmission" (You can definitely change the transmission directory. In that case you will see the specified path instead of /jffs/transmission above, but I have done with /jffs/transmission). Now you can access the transmission page using the following URL: http://192.168.1.1:9091/transmission/web/ (where 192.168.1.1 is my router IP). Please try these. I will be waiting for your response. Thanks
Christianwis : YES I did!
Christianwis:YES I did.
The following service must be seenif you login to the router with Telnet and fire the command "ps" : "transmissiond --config-dir /jffs/transmission"
Christianwis: in telnet the process transmissiond is missing... Undecided
  Christianwis: So... http://192.168.1.1:9091/transmission/web/ dont work..
why transmissiond is not up...?
thansk by the response and sorry by my english!
Christian
christianwis
Finally I could make
Finally I could make transmission work properly.
is not very friendly your settings.
For example:
1) the process transmissiond does not load if the directory is not configured on the website.
2) Then I could be accessed from the website
3) Another problem I had was the configuration directories, as if he did from windows from the client Transmission Remote GUI have to put the target in linux format, eg / mnt / sda / Torrent
and do not put it in windows format ejmplo x: Torrent.
Hope serves the rest.
regards,
Christian
christianwis
I cannt do work
thanks in advances,
Christian
Sayan Mukherjee
christianwis
Christian
christianwis
For example:
regards,
Christian
