Hello toghether,
I'm using the DD-WRT Firmware 'DD-WRT v24-sp2 (06/06/14) kongac' with my Netgear Nighthawk R7000.
I have one issue with OPENVPN. As client I'm using Tunnelblick 3.3.4 (build 3518.3872) on MACOSX. But also a test with an Windows GUI show the same issue.
What's my problem:
I'm using the Config in FW as an 'Daemon' and filled out CA Cert, Public Server Cert, Private Server Key, DH PEM and Additional Config. VPN connection can be established without a problem. My problem is, that I would use the WAN IP from my Netgear router and not WAN IP of provider where I established the connection to VPN server. Background: If I'm outside my country I would like to use my home country IP adress to use some streaming services restricted on my home IP adress only.
I tried some line in server config:
- push "route redirect-gateway"
- push "route 192.168.0.1 255.255.255.0"
Both configs have same result, no WAN IP from home router by checking 'http://www.myip.is'
Also on client side there is a check-box for 'Pushing whole network traffic over VPN server' The result, if I'm checkng this box is, that no internet side is reachable any more. I also used to ping 8.8.8.8, also not work. So no DNS issue.
I assume it's more a routing issue. Maybe someone can help?
See my server config:
Try this on dd-wrt:
www.dd-wrt.com/phpBB2/viewtopic.php?p=931272#931272
Try this when you configure dd-wrt:
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=931272#931272
Try this on dd-wrt:
