Please analyse log - i think my router has been highjacked
3 posts / 0 new
mmaryan
I have 3500l v2 with tomato shibby. Llast day i saw that my internet is unstable. I checked logline, and saw this: could someone kindly analyze it?
Jan  1 01:00:51 unknown syslog.info syslogd started: BusyBox v1.21.1
Jan  1 01:00:51 unknown user.notice kernel: klogd started: BusyBox v1.21.1 (2014-04-14 18:41:02 CEST)
Jan  1 01:00:51 unknown user.notice kernel: Linux version 2.6.22.19 (root@tomato) (gcc version 4.2.4) #2 Mon Apr 14 18:58:14 CEST 2014
Jan  1 01:00:51 unknown user.warn kernel: CPU revision is: 00019749
Jan  1 01:00:51 unknown user.warn kernel: Determined physical RAM map:
Jan  1 01:00:51 unknown user.warn kernel:  memory: 07fff000 @ 00000000 (usable)
Jan  1 01:00:51 unknown user.debug kernel: Entering add_active_range(0, 0, 32767) 0 entries of 256 used
Jan  1 01:00:51 unknown user.info kernel: Zone PFN ranges:
Jan  1 01:00:51 unknown user.warn kernel:   Normal          0 ->    32767
Jan  1 01:00:51 unknown user.warn kernel:   HighMem     32767 ->    32767
Jan  1 01:00:52 unknown user.info kernel: early_node_map[1] active PFN ranges
Jan  1 01:00:52 unknown user.warn kernel:     0:        0 ->    32767
Jan  1 01:00:52 unknown user.debug kernel: On node 0 totalpages: 32767
Jan  1 01:00:52 unknown user.err syslog: module usbcore not found in modules.dep
Jan  1 01:00:52 unknown user.notice kernel: Kernel command line: root=/dev/mtdblock15 console=ttyS0,115200
Jan  1 01:00:52 unknown user.warn kernel: Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Jan  1 01:00:52 unknown user.warn kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Jan  1 01:00:52 unknown user.info kernel: Synthesized TLB refill handler (20 instructions).
Jan  1 01:00:52 unknown user.info kernel: Synthesized TLB load handler fastpath (32 instructions).
Jan  1 01:00:52 unknown user.info kernel: Synthesized TLB store handler fastpath (32 instructions).
Jan  1 01:00:52 unknown user.info kernel: Synthesized TLB modify handler fastpath (31 instructions).
Jan  1 01:00:52 unknown user.warn kernel: PID hash table entries: 512 (order: 9, 2048 bytes)
Jan  1 01:00:52 unknown user.warn kernel: CPU: BCM5357 rev 2 pkg 10 at 480 MHz
Jan  1 01:00:52 unknown user.warn kernel: Using 240.000 MHz high precision timer.
Jan  1 01:00:52 unknown user.info kernel: console [ttyS0] enabled
Jan  1 01:00:52 unknown user.warn kernel: Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Jan  1 01:00:52 unknown user.warn kernel: Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Jan  1 01:00:52 unknown user.info kernel: Memory: 126464k/131068k available (33k kernel code, 4452k reserved, 2957k data, 128k init, 0k highmem)
Jan  1 01:00:52 unknown user.debug kernel: Calibrating delay loop... 239.20 BogoMIPS (lpj=1196032)
Jan  1 01:00:52 unknown user.warn kernel: Mount-cache hash table entries: 512
Jan  1 01:00:52 unknown user.info kernel: NET: Registered protocol family 16
Jan  1 01:00:52 unknown user.info kernel: usbcore: registered new interface driver usbfs
Jan  1 01:00:52 unknown user.info kernel: usbcore: registered new interface driver hub
Jan  1 01:00:52 unknown user.info kernel: usbcore: registered new device driver usb
Jan  1 01:00:52 unknown user.warn kernel: PCI: no core
Jan  1 01:00:52 unknown user.warn kernel: PCI: Fixing up bus 0
Jan  1 01:00:52 unknown user.info kernel: NET: Registered protocol family 2
Jan  1 01:00:52 unknown user.info kernel: Time: MIPS clocksource has been installed.
Jan  1 01:00:52 unknown user.warn kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan  1 01:00:52 unknown user.warn kernel: TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Jan  1 01:00:52 unknown user.warn kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Jan  1 01:00:52 unknown user.info kernel: TCP: Hash tables configured (established 4096 bind 4096)
Jan  1 01:00:52 unknown user.info kernel: TCP reno registered
Jan  1 01:00:52 unknown user.info kernel: squashfs: version 3.0 (2006/03/15) Phillip Lougher
Jan  1 01:00:52 unknown user.info kernel: io scheduler noop registered (default)
Jan  1 01:00:52 unknown user.info kernel: HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
Jan  1 01:00:52 unknown user.info kernel: N_HDLC line discipline registered.
Jan  1 01:00:52 unknown user.info kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 2 ports, IRQ sharing disabled
Jan  1 01:00:52 unknown user.info kernel: serial8250: ttyS0 at MMIO 0xb8000300 (irq = 8) is a 16550A
Jan  1 01:00:52 unknown user.info kernel: PPP generic driver version 2.4.2
Jan  1 01:00:52 unknown user.info kernel: MPPE/MPPC encryption/compression module registered
Jan  1 01:00:52 unknown user.info kernel: NET: Registered protocol family 24
Jan  1 01:00:52 unknown user.info kernel: PPPoL2TP kernel driver, V0.18.3
Jan  1 01:00:52 unknown user.info kernel: PPTP driver version 0.8.5
Jan  1 01:00:52 unknown user.err kernel: pflash: found no supported devices
Jan  1 01:00:52 unknown user.warn kernel: Found an ST compatible serial flash with 0 64KB blocks; total size 0MB
Jan  1 01:00:52 unknown user.err kernel: sflash: found no supported devices
Jan  1 01:00:52 unknown user.warn kernel: Found a Samsung NAND flash with 2048B pages or 128KB blocks; total size 128MB
Jan  1 01:00:52 unknown user.notice kernel: nflash: squash filesystem with lzma found at block 6304
Jan  1 01:00:52 unknown user.warn kernel: Boot partition size = 524288(0x80000)
Jan  1 01:00:52 unknown user.notice kernel: Creating 16 MTD partitions on "nflash":
Jan  1 01:00:52 unknown user.notice kernel: 0x00000000-0x00080000 : "boot"
Jan  1 01:00:52 unknown user.notice kernel: 0x00080000-0x00200000 : "nvram"
Jan  1 01:00:52 unknown user.notice kernel: 0x00200000-0x00240000 : "board_data"
Jan  1 01:00:52 unknown user.notice kernel: 0x00240000-0x00280000 : "POT1"
Jan  1 01:00:52 unknown user.notice kernel: 0x00280000-0x002c0000 : "POT2"
Jan  1 01:00:52 unknown user.notice kernel: 0x002c0000-0x00300000 : "T_Meter1"
Jan  1 01:00:52 unknown user.notice kernel: 0x00300000-0x00340000 : "T_Meter2"
Jan  1 01:00:52 unknown user.notice kernel: 0x00340000-0x00380000 : "ML1"
Jan  1 01:00:52 unknown user.notice kernel: 0x00380000-0x003c0000 : "ML2"
Jan  1 01:00:52 unknown user.notice kernel: 0x003c0000-0x00400000 : "ML3"
Jan  1 01:00:52 unknown user.notice kernel: 0x00400000-0x00440000 : "ML4"
Jan  1 01:00:52 unknown user.notice kernel: 0x00440000-0x00480000 : "ML5"
Jan  1 01:00:52 unknown user.notice kernel: 0x00480000-0x004c0000 : "ML6"
Jan  1 01:00:52 unknown user.notice kernel: 0x004c0000-0x00500000 : "ML7"
Jan  1 01:00:52 unknown user.notice kernel: 0x00500000-0x02000000 : "linux"
Jan  1 01:00:52 unknown user.notice kernel: 0x006283a0-0x02000000 : "rootfs"
Jan  1 01:00:52 unknown user.warn kernel: _nvram_init: allocat header: 2280849408, size= 32768
Jan  1 01:00:52 unknown user.info kernel: usbcore: registered new interface driver hiddev
Jan  1 01:00:52 unknown user.info kernel: usbcore: registered new interface driver usbhid
Jan  1 01:00:52 unknown user.info kernel: drivers/hid/usbhid/hid-core.c: v2.6:USB HID core driver
Jan  1 01:00:52 unknown user.warn kernel: u32 classifier
Jan  1 01:00:52 unknown user.warn kernel:     OLD policer on
Jan  1 01:00:52 unknown user.warn kernel: Netfilter messages via NETLINK v0.30.
Jan  1 01:00:52 unknown user.warn kernel: nf_conntrack version 0.5.0 (1024 buckets, 8192 max)
Jan  1 01:00:53 unknown user.warn kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan  1 01:00:53 unknown user.info kernel: ipt_account 0.1.21 : Piotr Gasidlo <[email protected]>, http://www.barbara.eu.org/~quaker/ipt_account/
Jan  1 01:00:53 unknown user.warn kernel: net/ipv4/netfilter/tomato_ct.c [Apr 14 2014 18:37:27]
Jan  1 01:00:53 unknown user.info kernel: NET: Registered protocol family 1
Jan  1 01:00:53 unknown user.info kernel: NET: Registered protocol family 10
Jan  1 01:00:53 unknown user.warn kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Jan  1 01:00:53 unknown user.info kernel: NET: Registered protocol family 17
Jan  1 01:00:53 unknown user.info kernel: 802.1Q VLAN Support v1.8 Ben Greear <[email protected]>
Jan  1 01:00:53 unknown user.info kernel: All bugs added by David S. Miller <[email protected]>
Jan  1 01:00:53 unknown user.warn kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan  1 01:00:53 unknown user.info kernel: Freeing unused kernel memory: 128k freed
Jan  1 01:00:53 unknown user.warn kernel: Warning: unable to open an initial console.
Jan  1 01:00:53 unknown user.warn kernel: emf: module license 'Proprietary' taints kernel.
Jan  1 01:00:53 unknown user.debug kernel: PCI: Setting latency timer of device 0000:00:02.0 to 64
Jan  1 01:00:53 unknown user.warn kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.110.27.20012
Jan  1 01:00:53 unknown user.warn kernel: wl_module_init: passivemode set to 0x0
Jan  1 01:00:53 unknown user.debug kernel: PCI: Setting latency timer of device 0000:00:01.0 to 64
Jan  1 01:00:53 unknown user.warn kernel: eth1: Broadcom BCM4329 802.11 Wireless Controller 5.110.27.20012
Jan  1 01:00:53 unknown user.warn kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan  1 01:00:53 unknown user.notice kernel: SCSI subsystem initialized
Jan  1 01:00:53 unknown user.info kernel: Initializing USB Mass Storage driver...
Jan  1 01:00:53 unknown user.info kernel: usbcore: registered new interface driver usb-storage
Jan  1 01:00:53 unknown user.info kernel: USB Mass Storage support registered.
Jan  1 01:00:53 unknown user.info kernel: ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Jan  1 01:00:53 unknown user.debug kernel: PCI: Setting latency timer of device 0000:00:04.1 to 64
Jan  1 01:00:53 unknown user.info kernel: ehci_hcd 0000:00:04.1: EHCI Host Controller
Jan  1 01:00:53 unknown user.info kernel: ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
Jan  1 01:00:53 unknown user.info kernel: ehci_hcd 0000:00:04.1: EHCI Fastpath: New EHCI driver starting
Jan  1 01:00:53 unknown user.info kernel: ehci_hcd 0000:00:04.1: irq 5, io mem 0x18004000
Jan  1 01:00:53 unknown user.info kernel: ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00
Jan  1 01:00:53 unknown user.info kernel: usb usb1: configuration #1 chosen from 1 choice
Jan  1 01:00:53 unknown user.info kernel: hub 1-0:1.0: USB hub found
Jan  1 01:00:53 unknown user.debug hotplug[473]: Attached USB device 1-0:1.0 [INTERFACE=9/0/0 PRODUCT=1d6b/2/206]
Jan  1 01:00:53 unknown user.info kernel: hub 1-0:1.0: 2 ports detected
Jan  1 01:00:53 unknown user.info sd-idle[478]: initialized
Jan  1 01:00:55 unknown user.debug kernel: vlan1: add 33:33:00:00:00:01 mcast address to master interface
Jan  1 01:00:55 unknown user.debug kernel: vlan1: add 01:00:5e:00:00:01 mcast address to master interface
Jan  1 01:00:55 unknown user.info kernel: vlan1: dev_set_allmulti(master, 1)
Jan  1 01:00:55 unknown user.info kernel: vlan1: dev_set_promiscuity(master, 1)
Jan  1 01:00:55 unknown user.info kernel: device eth0 entered promiscuous mode
Jan  1 01:00:55 unknown user.info kernel: device vlan1 entered promiscuous mode
Jan  1 01:00:57 unknown user.info kernel: device eth1 entered promiscuous mode
Jan  1 01:00:57 unknown user.info kernel: br0: port 2(eth1) entering forwarding state
Jan  1 01:00:57 unknown user.info kernel: br0: port 1(vlan1) entering forwarding state
Jan  1 01:00:57 unknown user.warn kernel: vlan2: Setting MAC address to  84 1b 5e da 6f 43.
Jan  1 01:00:57 unknown user.debug kernel: vlan2: add 33:33:00:00:00:01 mcast address to master interface
Jan  1 01:00:57 unknown user.debug kernel: vlan2: add 01:00:5e:00:00:01 mcast address to master interface
Jan  1 01:00:57 unknown user.info kernel: usb 1-1: new high speed USB device using ehci_hcd and address 2
Jan  1 01:00:57 unknown user.info kernel: usb 1-1: configuration #1 chosen from 1 choice
Jan  1 01:00:57 unknown user.info kernel: scsi0 : SCSI emulation for USB Mass Storage devices
Jan  1 01:00:57 unknown user.debug hotplug[542]: Attached USB device 1-1:1.0 [INTERFACE=8/6/80 PRODUCT=5e3/718/41]
Jan  1 01:00:57 unknown user.info kernel: IMQ starting with 2 devices...
Jan  1 01:00:57 unknown user.info kernel: IMQ driver loaded successfully.
Jan  1 01:00:57 unknown user.info kernel: 	Hooking IMQ after NAT on PREROUTING.
Jan  1 01:00:57 unknown user.info kernel: 	Hooking IMQ before NAT on POSTROUTING.
Jan  1 01:00:59 unknown user.notice kernel: scsi 0:0:0:0: Direct-Access     IC25N080 ATMR04-0         0041 PQ: 0 ANSI: 0
Jan  1 01:00:59 unknown user.notice kernel: sd 0:0:0:0: [sda] 156301488 512-byte hardware sectors (80026 MB)
Jan  1 01:00:59 unknown user.notice kernel: sd 0:0:0:0: [sda] Write Protect is off
Jan  1 01:00:59 unknown user.debug kernel: sd 0:0:0:0: [sda] Mode Sense: 03 00 00 00
Jan  1 01:00:59 unknown user.err kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jan  1 01:00:59 unknown user.info kernel:  sda: sda1
Jan  1 01:00:59 unknown user.notice kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jan  1 01:00:59 unknown user.debug init[1]: 182: pptp peerdns disabled
Jan  1 01:01:00 unknown user.warn kernel: fuse init (API version 7.8), DCACHE_BUG enabled
Jan  1 01:01:00 unknown daemon.info dnsmasq[632]: started, version 2.69test3 cachesize 1500
Jan  1 01:01:00 unknown daemon.info dnsmasq[632]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset Tomato-helper auth
Jan  1 01:01:00 unknown daemon.info dnsmasq[632]: asynchronous logging enabled, queue limit is 5 messages
Jan  1 01:01:00 unknown daemon.info dnsmasq-dhcp[632]: DHCP, IP range 192.168.1.101 -- 192.168.1.151, lease time 1d
Jan  1 01:01:00 unknown daemon.info dnsmasq[632]: reading /etc/resolv.dnsmasq
Jan  1 01:01:00 unknown daemon.info dnsmasq[632]: using nameserver 93.159.155.155#53
Jan  1 01:01:00 unknown daemon.info dnsmasq[632]: using nameserver 93.159.154.154#53
Jan  1 01:01:00 unknown daemon.info dnsmasq[632]: read /etc/hosts - 2 addresses
Jan  1 01:01:01 unknown daemon.info dnsmasq[632]: read /etc/dnsmasq/hosts/hosts - 5 addresses
Jan  1 01:01:01 unknown daemon.info dnsmasq-dhcp[632]: read /etc/dnsmasq/dhcp/dhcp-hosts
Jan  1 01:01:01 unknown daemon.notice ntfs-3g[654]: Version 2013.1.13 integrated FUSE 27
Jan  1 01:01:01 unknown daemon.notice ntfs-3g[654]: Mounted /dev/sda1 (Read-Write, label "Nowy", NTFS 3.1)
Jan  1 01:01:01 unknown daemon.notice ntfs-3g[654]: Cmdline options: iocharset=utf8,noatime,nodev
Jan  1 01:01:01 unknown daemon.notice ntfs-3g[654]: Mount options: iocharset=utf8,nodev,allow_other,nonempty,noatime,fsname=/dev/sda1,blkdev,blksize=4096
Jan  1 01:01:01 unknown daemon.notice ntfs-3g[654]: Ownership and permissions disabled, configuration type 1
Jan  1 01:01:01 unknown user.info hotplug[615]: USB ntfs fs at /dev/sda1 mounted on /tmp/mnt/Nowy
Oct  6 08:56:40 unknown daemon.notice miniupnpd[788]: version 1.8 started
Oct  6 08:56:40 unknown daemon.notice miniupnpd[788]: HTTP listening on port 28791
Oct  6 08:56:40 unknown daemon.notice miniupnpd[788]: Listening for NAT-PMP traffic on port 5351
Oct  6 08:56:41 unknown daemon.err apcupsd[497]: apcupsd FATAL ERROR in linux-usb.c at line 609 Cannot find UPS device -- For a link to detailed USB trouble shooting information, please see <http://www.apcupsd.com/support.html>.
Oct  6 08:56:41 unknown daemon.err apcupsd[497]: apcupsd error shutdown completed
Oct  6 08:56:42 unknown authpriv.warn dropbear[799]: Failed loading /etc/dropbear/dropbear_ecdsa_host_key
Oct  6 08:56:42 unknown authpriv.info dropbear[801]: Running in background
Oct  6 08:56:42 unknown daemon.info dnsmasq[632]: exiting on receipt of SIGTERM
Oct  6 08:56:42 unknown daemon.info dnsmasq[831]: started, version 2.69test3 cachesize 1500
Oct  6 08:56:42 unknown daemon.info dnsmasq[831]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset Tomato-helper auth
Oct  6 08:56:42 unknown daemon.info dnsmasq[831]: asynchronous logging enabled, queue limit is 5 messages
Oct  6 08:56:42 unknown daemon.info dnsmasq-dhcp[831]: DHCP, IP range 192.168.1.101 -- 192.168.1.151, lease time 1d
Oct  6 08:56:42 unknown daemon.info dnsmasq[831]: reading /etc/resolv.dnsmasq
Oct  6 08:56:42 unknown daemon.info dnsmasq[831]: using nameserver 93.159.155.155#53
Oct  6 08:56:42 unknown daemon.info dnsmasq[831]: using nameserver 93.159.154.154#53
Oct  6 08:56:42 unknown daemon.info dnsmasq[831]: read /etc/hosts - 2 addresses
Oct  6 08:56:42 unknown daemon.info dnsmasq[831]: read /etc/dnsmasq/hosts/hosts - 5 addresses
Oct  6 08:56:42 unknown daemon.info dnsmasq-dhcp[831]: read /etc/dnsmasq/dhcp/dhcp-hosts
Oct  6 08:56:42 unknown user.debug init[1]: starting rstats.
Oct  6 08:56:42 unknown user.debug init[1]: starting cstats.
Oct  6 08:56:57 unknown user.notice root: Stoping NFS Server ...
Oct  6 08:56:57 unknown user.info init[1]: Netgear WNR3500L v2: Tomato 1.28.0000 MIPSR2-117 K26 USB AIO
Oct  6 08:56:59 unknown user.notice root: Transmission daemon successfully stoped
Oct  6 08:57:03 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:03 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:03 unknown user.notice root: NFS Server stoped ...
Oct  6 08:57:04 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:04 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:05 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:05 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:06 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:06 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:07 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:07 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:07 unknown daemon.info dnsmasq-dhcp[831]: DHCPREQUEST(br0) 192.168.1.120 00:e3:b2:0d:0d:2a
Oct  6 08:57:07 unknown daemon.info dnsmasq-dhcp[831]: DHCPACK(br0) 192.168.1.120 00:e3:b2:0d:0d:2a android-cf8ec0f82010d9cf
Oct  6 08:57:08 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:08 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:08 unknown daemon.err nmbd[933]: process_nmb_request: Multihomed registration request must be directed at a WINS server.
Oct  6 08:57:09 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:09 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:10 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:10 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:10 unknown daemon.err nmbd[933]: process_nmb_request: Multihomed registration request must be directed at a WINS server.
Oct  6 08:57:11 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:11 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:11 unknown daemon.info dnsmasq-dhcp[831]: DHCPREQUEST(br0) 192.168.1.101 80:56:f2:03:ab:2d
Oct  6 08:57:11 unknown daemon.info dnsmasq-dhcp[831]: DHCPACK(br0) 192.168.1.101 80:56:f2:03:ab:2d cpap
Oct  6 08:57:12 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:12 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:13 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:13 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:14 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:14 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:15 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:15 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:15 unknown daemon.info dnsmasq-dhcp[831]: DHCPREQUEST(br0) 192.168.1.102 04:46:65:6c:a9:24
Oct  6 08:57:15 unknown daemon.info dnsmasq-dhcp[831]: DHCPACK(br0) 192.168.1.102 04:46:65:6c:a9:24 android-sgs2-rafal
Oct  6 08:57:16 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:16 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:17 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:17 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:18 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:18 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:19 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:19 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:20 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:20 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:21 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:21 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:22 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:22 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:23 unknown daemon.err nmbd[933]: collect_all_workgroup_names_from_wins_server:
Oct  6 08:57:23 unknown daemon.err nmbd[933]: Cannot find my workgroup WORKGROUP on subnet UNICAST_SUBNET.
Oct  6 08:57:24 unknown daemon.err nmbd[933]: ===============================================================
Oct  6 08:57:24 unknown daemon.err nmbd[933]: INTERNAL ERROR: Signal 11 in pid 933 (3.0.37)
Oct  6 08:57:24 unknown daemon.err nmbd[933]: Please read the Trouble-Shooting section of the Samba3-HOWTO
Oct  6 08:57:24 unknown daemon.err nmbd[933]: From: http://www.samba.org/samba/docs/Samba3-HOWTO.pdf
Oct  6 08:57:24 unknown daemon.err nmbd[933]: PANIC (pid 933): internal error
Oct  6 08:57:24 unknown daemon.err nmbd[933]: unable to produce a stack trace on this platform
Oct  6 08:57:24 unknown daemon.err nmbd[933]: dumping core in /var/log/cores/nmbd
Oct  6 09:00:01 unknown syslog.info root: -- MARK --
Oct  6 09:23:00 unknown user.info sd-idle[478]: spinning down /dev/sda
Oct  6 09:28:20 unknown daemon.info dnsmasq-dhcp[831]: DHCPREQUEST(br0) 192.168.1.102 04:46:65:6c:a9:24
Oct  6 09:28:20 unknown daemon.info dnsmasq-dhcp[831]: DHCPACK(br0) 192.168.1.102 04:46:65:6c:a9:24 android-sgs2-rafal
Oct  6 09:54:04 unknown daemon.info dnsmasq-dhcp[831]: DHCPREQUEST(br0) 192.168.1.127 00:e3:b2:07:fc:a8
Oct  6 09:54:04 unknown daemon.info dnsmasq-dhcp[831]: DHCPACK(br0) 192.168.1.127 00:e3:b2:07:fc:a8 android-6e846442ca640f8e
JTB
No it seems you're samba
No it seems you're samba (windows shares) settings are faulty, try to reconfigure that and see if the logs calm down after that.
JTB
