Hello All,
I've recently purchased the R8000 but noticed that the R7000 has Tomato. Will they R8000 have a release as well since the hardware is very similair? Anyone have idea or additional knowledge? If at worse I can return R8000 and get the 7000. I'm really wanting Tomato for my router.
Thanks for your time and attention,
Did you find a solution for installing tomato on your netgear R8000? I installed the standard version of dd-wrt on mine, But I cannot find a big or mega version for it to be able to run openvpn.
I have OpenVPN on mine.
DD-WRT v24-sp2 (11/25/14) std (SVN revision build r25344)
I'd rather have Tomato but DD-WRT will work for now.
Cheers,
I tried the HMA auto-installer and it did not work for me. Did you use an automatic installation method from a vpn service provider or the manual setup?
Ah, OK. If you are attempting to use OpenVPN Client connection. You have to get the config from the provider. I always set up my stuff manually. Make sure you have logging enabled so you can see where you are getting hung up at. Additional options turn on verbose -5
