R7000 bricked? Flashed DD-WRT to Tomato - cannot login: user/pw denied
62 posts / 0 new
hippy
hippy's picture
that will work as long as the
pictures in this thread
Mex
Mex's picture
cable came i setup exactly
next step was jtag,
hippy
hippy's picture
not sure the cable you got
ArtemR
ArtemR's picture
Hi Guys,
Hi Guys,
baikan4ik
baikan4ik's picture
Method via telnet helped me.
cyberdiver
cyberdiver's picture
bill1228
bill1228's picture
Girlpopup said: Hi Shibby,
Girlpopup said: Hi Shibby, Ok, I've tried your last post. Here what I got: --- JUNO:~ mariela$ telnet 192.168.1.1 233 Trying 192.168.1.1... Connected to rt-c404155bb20c. Escape character is '^]'. /tmp # nvram get http_password /tmp # nvram get http_username $1$ItDUMpXa$NGb89HxhW8hZMKRWs4LNw. /tmp # --- Username is really crazy value, but trying to get password returns nothing. Any idea? I have window on my mac, i could try putty if it really could make any difference. Thanks a lot!
--bill
Romek
Romek's picture
Hey Guys,
Hey Guys,
Many Thanks
eych
eych's picture
Hi
Hi
Thnx in advance :)
aamjohns
aamjohns's picture
I want to thank Shibby, and the rest of you - I was worried there for a bit.  I did watch the video instructions but I guess I did not realize that going back to the Netgear firmware was a step.  I did this, like many others, from DD-WRT and ran into this problem.
and then I looked through the list for http_username and http_password.  I copy/pasted each into a text document and then used those to log into the router interface.
Definitely be sending a donation.  Not just because I am not bricked, but for the hard work that goes into this firmware.
tobias.
se7six
se7six's picture
Thank you for that
Zaphodbblx
Zaphodbblx's picture
Is this why we should reset
Jackfrost6022
Jackfrost6022's picture
Hey all,
Hey all,
Do this:
1) run router and wait 2-3
5) use result as password
Roy2001
Roy2001's picture
I was too excited and lazy
Sleepy_Eyez
Sleepy_Eyez's picture
Hi everyone,
Hi everyone,
You know why I'm here lol..
I have many questions.
I downloaded putty.exe
Antioch
Antioch's picture
Do this:1) run router and
Do this:
This might be a dumb question, but what is the wifi on/off button? I only have a on/off button and as far as I can tell from pictures on the router online there never has been anything other than an on/off button for the R7000. I tried holding the On/off button for a really long time and it doesn't seem to do anything, I only ever get connection refused on telnet port 233, no matter how long I hold the button. Also if I do this with the Router on, all that does is turn it off again after releasing the button. I am just retarded? What am I doing wrong here?
Antioch
Antioch's picture
Nevermind, I got it. In case
Squiddley
Squiddley's picture
Thank you so much for this
Username : $1$MPQQ.4Xs$AFd4hOL5GpgdcXt8.lNg10
Password :  $1$MPQQ.4Xs$QlIYohWICjYaUkIpc1IO./
I have tried many many times, cross checking each time that I have entered the date, but CANNOT login.
Any advice gratefully received... this is killing my sanity !
Squiddley
Squiddley's picture
Problem [simply] resolved ! I
Anonikat
Anonikat's picture
Thank You!! shibby :) that
Thank You!! shibby :) that work for my Netgear R6300v2CH heartyes
RomanST
RomanST's picture
Got a R6300v2 CH from Amazon
Got a R6300v2 CH from amazon for $37 shipped. I wanted to try those out since they appear abundant as used on amazon and way cheaper than EA6500 but essentialy the same hardware and they run cooler (70C vs 95C... much better ventilation holes)!!! They also dont appear to have the nvram bug the EA's have. I currently have 5x E3200 and 8x EA6500 Shibby powered Tinc routers around the state and US for family backup and media sharing.
<Wait 5 min>
Full NVRam reset
Flash to Tomato shibby R6300v2 with Reset defaults selected from DD-Wrt (I dont think the reset does anything...)
<Wait 10 min>
Press and hold the WIFI button for 30 seconds (5 sec more just incase)
nvram show|grep http
User: root
Celebrate...
Tinc has been a life saver...
Pere
Pere's picture
Hello
Hello
Is it a useless idea?
stuccoman
stuccoman's picture
thank you Shibby for the how
thank you Shibby for the how to. I managed to brick mine writing tomato to it before resetting back to factory. I found my way in the back door and got the encrypted key.  Just bought this router and I am not the most computer suave. I had kids bitching and moaning at the same time that they had no wifi and I had the wife looking at me with a stern look thinking she just threw $200 plus away yesterday buying this router....
CHeers
Pere
Pere's picture
Glenn_k9
Glenn_k9's picture
I read somewhere that if you
aaronrz
aaronrz's picture
campbeln
campbeln's picture
Shibby's [updated] notes
darkjoy
darkjoy's picture
I tried all of the suggested methods (including the Shibby's [updated] notes), apart of getting a usb to ttl cable.
Having a firmware available that actually bricked so many routers is a shameful thing. I'm so pissed of that I didn't read all of the complains before I followed the video instruction. angry
Thanks for any help
ismaelgokufox
ismaelgokufox's picture
Is there a way to install
badboy416
badboy416's picture
I almost gave up. Nothing was
