Linksys WRT54GL 1.1
Tomato Firmware v1.28.1816
when I try to set Access Restriction against the MAC adress I see no results, I can't see any restrictions on the blocked computer (Block All Internet Access is set). After more tests I see that there are no resetrictions even when I set Applies to All Computer/Devices.
I would appreciate your help with debugging this issue, I am not too much experienced in such problems.
Wojtek
I still investigate the problem. I added a simple run in 'Access Restriction" to have ip 192.168.1.12 blocked all the time. When I ssh to router
I am surprised the following commands return nothing:
iptables -L -n -v | grep 192.168.1.12
cat /etc/iptables | grep 192.168.1.12
Does no output suggest that iptables is not aware of changes I put with web "Access Restriction" form?
Hi
Try blocking by the MAC address
