Dear all i juste flashing my R7000 to dd-wrt.K3_R7000.chk router is ok and reboot , make my old backup config file and reboot , just after the router is boot and all led are ready white not blinking or amber led power , so the ip adresse and identification dhcp not work , just have access to 192.168.1.1 after reboot router 10 second past ping fine , and after no ping avaible.
i m use netgear recovery tool by tftp and impossible to send firmware try 3 times and ay unable to get responses from the server .
what way to reset dd-wrt to clean configuration 30/30/30 not work and test other rest and not change setting or status.
Verry big help thx you :)
You will need to unbrick it using a serial cable.
See my post in the other thread in this sub-forum.
