Quick question:
Does Kong's DD-WRT firmware have a build in firewall? How I enable it if it does?
Firewall is a basic feature of all router solutions.
What you want to mean by the term "build in firewall" ?? Which Firewall feature do you specifically need ???
Thanks, I just wanted to know if the router firmware included a firewall. I don't need any feature per say. I should have just checked my router page... I found the SPI firwall under security.
You will find some more in "Access Restriction" tab.
I am also looking for some firewall/whitelist/blacklist functionality for a WRT3500L router.
In particular, I have a port forwarding incoming rule to an http server on my LAN, and generally most visitors are nice. Some are not and I want to block their IP address at the netgear.
Is there any firmware that can support this?
