Hi all!
Where i can set a DHCP reservation on last "DD-WRT firmware for Netgear R7000 Based on revision 27261" ?
I can't find the right option... :(
Hi all!
Check the links below and have a try.
http://www.dd-wrt.com/wiki/index.php/Static_DHCP
http://superuser.com/questions/601694/how-can-i-tell-dd-wrt-dhcp-to-assi...
http://www.howtogeek.com/69612/how-to-set-up-static-dhcp-on-your-dd-wrt-...
Good Luck !
