I am just wondering, do I just go into the firmware update and just put the .chk file and just revert it or how do you do it? I just want to know this because I'm still thinking of flashing the router to the newest flash firmware. And if I wanted to, I could reset it.
Guys can you help me quickly? I need an answer shortly because I am doing it right now.
I would like to know the answer too. Thanks in advance for any help.
Brian
I just flashed kongs latest rom but i want to restore back to stock firmware. I cannot login to my router setting and says my router is not found in the netgear genie app when i try to login. How can i resore back? Im on a mac if that makes a difference or not.
Can you get into your flashed router through the browser by typing 192.168.1.1? The netgear genie app only works for stock firmware, it should not work after flashing to dd-wrt.
By the way, what is your experience for the flashed R6700? Any comments and ideas are welcome. Thanks in advance.
Brian
