Hey guys so I have the Netgear R7000 and I have been wanting to flash my router to DD-WRT. On this web sit there are 2 files from what I can tell.
DD-wrt Kong Mod R7000_06_30_2015Chk (1391)
DD-wrt K3_R7000_1-jul-2015.chk (2506)
Which one is better??
If you guys can recommend which one will work better with my isp speeds which are:
TWC
300 down
20 up
Thanks for your help.
You will start with the below mentioned firmware, which I have used for quite some times. It is the best as far as I am concern.
DD-WRT firmware for Netgear R7000 Based on revision 27261
