can no longer login, but still online!
4 posts / 0 new
kuchenmann
kuchenmann's picture
After I played around with Tomato, I installed dd-wrt again. Then I wanted to give Tomato another try. Started with initial Tomato firmware.
But something went wrong. Now I can not login to router again, does not accept any user/pw combination I am trying. admin/admin, admin/password, root/admin,
admin/myownpassword, etc.  But still get login prompt, even when trying telnet to router. But none user-pw works.
But still can connect to internet and even WLAN works with WPA2/AES.
Is there something I can do now? Maybe I should try debrick with TTL-USB-cable?
alienhead
alienhead's picture
I have the same problem.
alienhead
alienhead's picture
Just in case you are still
Just in case you are still stuck, i found this and it partially worked for me. After gaining access, there was no result to the http_password command, so I did nvram erase, reboot, 30-30-30:
Flashed from kong to tomato having forgot about needing to flash to
original first. Now i cannot login to 192.168.1.1 with admin:admin
I read shibby's post:
In dd-wrt password is encrypted and this is why old password does not work after install tomato (or back from dd-wrt to Genie).
Do this:
1) run router and wait 2-3
5) use result as password
kuchenmann
Great advise! Backdoor worked
Great advise! Backdoor worked. After backdoor access and reboot 30/30/30 I had login to Tomato-GUI again and now am setting up router again. Thanks a lot!
