Hello friends,
I wanted to tell them the inconveniences I had with the latest version of 11.28.2014.
1) Take a backup of the previous firmware and then restore to the new, however it did not work and I had to re configure again the router completely.
2) This installation the DNLA did not work, I can not see any music video or photos. Please could you tell me how to lift the DNLA service or check?
3) I Can not do port forwardin to remote desk.. port 3389 to 3390 both.
Why ? I dont know, with the firmware old y can perfectly.. if can to help me please!!
The work we are doing is fantastic and my opinion is constructive ..
Thank you very much,Christian
Restore Configuration backup, DNLA and Port Forwarding all are working fine with this firmware. I have not found any notable issues.
Could you please elaborate the settings that you are running in DDWRT firmware for the above issues mentioned?
Could someone please post their config settings with both radios bonded?
I tried the current version and had really slow wifi speed.
Also, was their a fix for WAN throughput?
请问香港固件,大陆刷什么固件好
Hello Every One,
1. I Have Netgear Nighthawk X6 (R8000) With DD-WRT Firmware.
2. Unfortunately I change overclocking setting from 1000MHz to
1400MHz now the router boots but I can't find Wifi Network or when I
plug the wire mannualy I can't ping the default gateway which is
192.168.1.1 and even I can't access GUI.
3. Any Suggestion what should I do, Is it possible to fix the issue by flashing the nvram?
Please Help some one. Thanks..
