Hi all,
I attempted to flash my R6200v2 and I believe I managed to brick it. When I power it up the power light is orange and after a 10 seconds or so, all the lights light up quickly and it goes back to orange. At that point, I'm able to ping it.
I tried the 30-30-30 restart and also tried TFTP recovery. I can't seem to get TFTP to talk to the router but it does respond to pings at 192.168.1.1 for a brief window of time so I'm thinking TFTP recovery is a possibility.
Here are the TFTP commands I tried. I'm using Linux and tried an arp command with the router mac address but it will only respond to pings if I don't provide the arp entry and let that happen on it's own. The TFTP transfer times out after the 60 tries.
binary
rexmt 1
timeout 60
put filename
Anything else I should/can try before going the usb serial cable route?
I had this same problem but had a waaranty on my device from Amazon and sent back. I have a new one amd i'm afraid to flash again. would be nice tomhave an answer to this!! its probably the only way I will flash again.
I am wondering about recovery in case I mess up . I can't seem to find anything
